Hello guys,
I'm new to Arduino and looking for your help, I'm working on a Door Lock System tutorial which I found on arduinogetstarted.com with a 3x4 Keypad, LCD, BUZZER and a Relay, I modified the code to fit my own idea and I'm having a problem, simply I'm trying to make the BUZZER make a beep sound every time I press a key, I tried different methods using tone() but it didn't work, so please advice
Full code is attached
#include <Keypad.h>
#include <LiquidCrystal.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] =
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {6 , A1, 2, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 7, 3}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
const int rs = 13, en = 12, d4 = 11, d5 = 10, d6 = 9, d7 = 8;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
const int RELAY_PIN = A0; // the Arduino pin, which connects to the IN pin of relay
const String password_1 = "03121990"; // change your password here
String input_password;
int cursorColumn = 0;
input_password.reserve(16); // maximum input characters is 33, change if needed
pinMode(RELAY_PIN, OUTPUT); // initialize pin as an output.
digitalWrite(RELAY_PIN, HIGH); // lock the door
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("ENTER PASSWORD:");
char key = keypad.getKey();
if (key)
if(key == '*')
input_password = ""; // reset the input password
lcd.clear();
} else if(key == '#')
lcd.clear();
if(input_password == password_1)
lcd.print("CORRECT!");
lcd.setCursor(0, 1);
lcd.print("DOOR UNLOCKED!");
digitalWrite(RELAY_PIN, LOW); // unlock the door for 20 seconds
delay(2000);
lcd.clear();
delay(10000);
lcd.print("INCORRECT!");
lcd.print("ACCESS DENIED!");
delay(2000);
lcd.clear();
if(input_password.length() == 0) {
lcd.clear();
input_password += key; // append new character to input password string
lcd.setCursor(input_password.length(), 2); // move cursor to new position
lcd.print('*'); // print * key as hiden character
sketch_oct21b.ino (2.3 KB)
