beep sound
hello ,, i'm trying to find code that play beep sound from pc thank you .
Why the shouting (aka bold)? And we are not Google. If you want to find something, use that. Or try this "code": https://www.youtube.com/watch?v=IoPBsR_Zj7k
If you want to make a Arduino project that bleeps that's a different story. Tell us what you want, show us what you have (code, circuit diagram) etc and will help you. But you have to do the work ;)
Did you have an Arduino question?
ok sorry for that
i’m new user for ardiuno and this is my first project
i built a small circuit of temp. sensor ( DHT22 ) , arduino UNO and xbee modules
all i need now to get beep or any sound ( as alarm ) from PC ,when temperature readings become high
this is my code :
#include <SoftwareSerial.h>
#include "DHT.h"
#define DHTPIN 7
#define DHTTYPE DHT22
int maxHum = 60;
int maxTemp = 20;
SoftwareSerial XBee(2, 3);
DHT dht(DHTPIN, DHTTYPE);
  dht.begin();
XBee.begin(9600);
      delay(2000);
  float h = dht.readHumidity();
    float t = dht.readTemperature();
  if (isnan(h) || isnan(t)) {
    XBee.println("Failed to read from DHT sensor!");
    return;
  if (h > maxHum ) {
    XBee.println(" warrning hum.");
    Console.Beep();
if (t >  maxTemp ) {
  XBee.println( " warrning temp. ");
  Console.Beep();
  XBee.print("Humidity: ");
  XBee.print(h);
  XBee.print(" %\t");
  XBee.print("Temperature: ");
  XBee.print(t);
  XBee.println(" *C ");
 if (Serial.available())
    XBee.write(Serial.read());
  if (XBee.available())
    Serial.write(XBee.read());
Thank you all …
In the ASCII character coding, 7 is the BEL (bell) character. In C one can use "\a" in a printed character string to generate the BEL character. A particular terminal emulator may or may not actually make a tone when it encounters this character. Some will simply print something that indicates a non-printable character in the string.
