Hello, some body can help to correct error as follow C code (4 digit of 7 segment):
----------------------C code ----------------------------------------
const int numeral[10] = {
//ABCDEFG /dp
B11111100, // 0
B01100000, // 1
B11011010, // 2
B11110010, // 3
B01100110, // 4
B10110110, // 5
B00111110, // 6
B11100000, // 7
B11111110, // 8
B11100110, // 9
// pins for decimal point and each segment
// DP, G, F, E, D, C, B, A
const int segmentPins[ ] = { 13, 8, 7, 6, 5, 4, 3, 2 };
const int nbrDigits= 4; // the number of digits in the LED display
//dig 0 1 2 3
const int digitPins[ nbrDigits] = { 9, 10, 11, 12 };
for(int i=0; i < 8; i++) {
pinMode(segmentPins[ i] , OUTPUT); // set segment and DP pins to output
for (int i=0; i < nbrDigits; i++) {
pinMode(digitPins[ i] , OUTPUT);
int value = analogRead(0);
showNumber(value);
void showNumber( int number)
if(number == 0) {
showDigit( 0, nbrDigits‐1); // display 0 in the rightmost digit
// display the value corresponding to each digit
// leftmost digit is 0, rightmost is one less than the number of places
for (int digit = nbrDigits‐1; digit >= 0; digit‐‐) {
if(number > 0) {
showDigit( number % 10, digit);
number = number / 10;
// Displays given number on a 7‐segment display at the given digit position
void showDigit( int number, int digit)
digitalWrite( digitPins[ digit] , HIGH );
for(int segment = 1; segment < 8; segment++) {
boolean isBitSet = bitRead(numeral[ number] , segment);
// isBitSet will be true if given bit is 1
// isBitSet = ! isBitSet; // Code Option*
// uncomment the above Code Option line for common anode display
digitalWrite( segmentPins[ segment] , isBitSet);
delay(5);
digitalWrite( digitPins[ digit] , LOW );
---------------------------error messages-------------------------
Arduino: 1.6.6 (Windows 7), Board: "Arduino Nano, ATmega328"
_7Segment_x_4_Nano_1:41: error: stray '\342' in program
showDigit( 0, nbrDigits�1); // display 0 in the rightmost digit
_7Segment_x_4_Nano_1:41: error: stray '\200' in program
_7Segment_x_4_Nano_1:41: error: stray '\220' in program
_7Segment_x_4_Nano_1:45: error: stray '\342' in program
for (int digit = nbrDigits�1; digit >= 0; digit��) {
_7Segment_x_4_Nano_1:45: error: stray '\200' in program
_7Segment_x_4_Nano_1:45: error: stray '\220' in program
Z:\D\TECH MANUAL BOOKS\1_TU SACH VI XU LY\Arduino\Proteus file cho Arduino UNO_7Segment_x_4_Nano_1_7Segment_x_4_Nano_1.ino: In function 'void showNumber(int)':
_7Segment_x_4_Nano_1:41: error: expected ')' before numeric constant
_7Segment_x_4_Nano_1:45: error: expected ';' before numeric constant
_7Segment_x_4_Nano_1:45: error: expected ')' before ';' token
_7Segment_x_4_Nano_1:45: error: 'digit' was not declared in this scope
_7Segment_x_4_Nano_1:45: error: expected ';' before ')' token
_7Segment_x_4_Nano_1:67: error: expected '}' at end of input
exit status 1
enabled in File > Preferences.
arduino C code question_1.pdf (86.7 KB)
