Beginer, how to do this?
x;y;a variables
if x do y until a.
Plese help, i dont know how to type this in the, correct way.
i tried
case 5:
Right(150, 150);
if(senRight){
else{
Right(150, 150);
it didnt work ;(
if x do y until a.
Until a what?
Use this format:
while(a) {
if(x) {
//put your "do y" code here
The outline code in Reply #2 has no means to change the value of the variable a so the WHILE will never terminate.
@Hyper12347, it will be much easier (for you as well as us) to figure out a solution if you use meaningful names for your variables rather than single characters.
...R
Robin2:
Granted but since the question was so generic, I intended for 'a' to be a placeholder for some sort of conditional test. For example, 'a' might be (adc_reading > 200) or something like that. How the conditional test establishes a change in state is something to be handled elsewhere and again, that isn't clearly defined.
Gahhhrrrlic:
I do understand. But unintentional infinite WHILE loops are a very common problem on the Forum so it is well to preempt the issue.
...R
Good point.
