Hello,
I am really new to arduino and coding. I come from a different background.
I want to change the value of variable in my setup.
so if the button was pressed increment by a value and when released after a period of time move on to run the loop.
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include <Adafruit_GFX.h>
#include <Wire.h>
#include <JC_Button.h>
//#include <LiquidCrystal.h> //Default Arduino display Librarey is included
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Button Charge_Button(3, 25, false, true);
int batt_h = 2;
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
while (true);}
Charge_Button.begin();
Charge_Button.read();
if (Charge_Button.wasPressed())
batt_h +.1;
Serial.println(batt_h);
if (Charge_Button.pressedFor(1000))
loop;
// Check for button presses until a long press
while (!Charge_Button.pressedFor(1000))
// Button pressed. Increment value.
batt_h += 0.1;
I'm going to guess this is probably the code you want in loop(). However, it doesn't make sense to add .1 to an integer and you should never call loop from loop(). batt_h +.1 doesn't do anything.
Hey,
Yeah I tested it in setup and seen it doesn’t run.
I’m adding .1 as cut off voltage for batteries is different.
Ok so I have it functioning for when button pressed it increments, but I want it to move on to next part of code once I do a long press.
Or if I created an array
Cutoff_voltage =[1,2,3] how would I use the button to select one of these values
@johnwasser has given you code that will work if you change batt_h to a float type. It will keep incrementing until the button is pressed for more than 1000ms.
Sorry to pester you again, what would be an example I could put after johns code to show when button is pressed for 1second that it exits the while loop? could i put a print function?
thank you @johnwasser. As I am increasing my coding skills,
what about an attachinterrupt to increase or decrease the PWM while the code is running to control current.
would I be best to do it on the Rising or falling when the button is pushed? the documentation is beneficial I was just wondering is there any "real" world examples
