Hi, i’m trying to control 2 different circuits with one code…how do i combine them together so they occur at the same time?
I realise there must be a simpler method of coding the numeric display output but haven’t figured this out yet.
Heres some code:
i
nt pin1 = 2;
int pin2 = 3; // --6--
int pin3 = 4; // 5 | | 7
int pin4 = 5; // |--4--|
int pin5 = 6; // 1 | | 3
int pin6 = 7; // --2--
int pin7 = 8;
int gnd1 = 11; // gnd1 is display 1's gnd
int gnd2 = 9; // gnd2 is display 2's gnd
int timer = 500; // A timer, to run the for loop 500 times, which turns out as 1 second.
int value; // The value, part of the FADING display
void setup(){
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT); //The following sets up all of the pins for use.
pinMode(pin5, OUTPUT);
pinMode(pin6, OUTPUT);
pinMode(pin7, OUTPUT);
pinMode(gnd1, OUTPUT);
pinMode(gnd2, OUTPUT);
for (int i=0; i<timer; i++){ // The for loop, for running the program 500 times.
digitalWrite(pin1, B1);
digitalWrite(pin2, B1);
digitalWrite(pin3, B1);
digitalWrite(pin4, B0);
digitalWrite(pin5, B1);
digitalWrite(pin6, B1);
digitalWrite(pin7, B1);
digitalWrite(gnd1, B0);
digitalWrite(gnd2, B1);
delay(0.5); // Writes 03 to the display.
digitalWrite(pin1, B0);
digitalWrite(pin4, B1);
digitalWrite(pin5, B0);
digitalWrite(gnd1, B1);
digitalWrite(gnd2, B0);
delay(0.5);
delay(0.5); // Writes 02 to the display.
digitalWrite(pin3, B0);
delay(0.5);
delay(0.5); // Writes 01 to the display.
digitalWrite(pin2, B0);
digitalWrite(pin6, B0);
delay(0.5);
delay(0.5); // Writes 00 to the display.
delay(0.5);
digitalWrite(13, HIGH); // Turns the TIMER ENDED LED on.
for(value = 0 ; value <= 255; value+=5) // fade in (from min to max)
analogWrite(gnd1, value); // sets the value (range from 0 to 255)
analogWrite(gnd2, value); // sets the value (range from 0 to 255)
delay(10); // waits for 30 milli seconds to see the dimming effect
for(value = 255; value >=0; value-=5) // fade out (from max to min)
delay(10);
Now, how do i add this in so they run at the same time:
int ledPin = 13; // LED connected to digital pin 9
void setup() { // nothing happens in setup
// fade in from min to max in increments of 5 points:
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
// sets the value (range from 0 to 255):
analogWrite(ledPin, fadeValue);
// wait for 30 milliseconds to see the dimming effect
delay(30);
// fade out from max to min in increments of 5 points:
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
delay(30);
Thanks
K
