Beginner help with Ethernet shield
Hello,
I am looking for some basic help with the ethernet shield.
I have got it up and running and all the demo Web server apps are running.
What I want to do is getting analog values and control outputs via telnet or any remote access method.
What I want to know is how the remote access works when sending some strings.
For example, this simple code found in the Ethernet shield library;
#include <Ethernet.h>
// network configuration.  gateway and subnet are optional.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 10, 0, 0, 177 };
byte gateway[] = { 10, 0, 0, 1 };
byte subnet[] = { 255, 255, 0, 0 };
// telnet defaults to port 23
Server server = Server(23);
  // initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);
  // start listening for clients
  server.begin();
  Client client = server.available();
  if (client) {
    server.write(client.read());
I can Telnet and I get:
m26k9@desktop:~$ telnet 192.168.0.20
Trying 192.168.0.20...
Connected to 192.168.0.20.
Escape character is '^]'.
telnet>test
?invalid command
But I am having trouble after this.
What does the server.write(client.read()); code actually do?
I was thinking it will echo what I write but all I get is ?invalid command.
Any help with this is greatly appreciated.
Thank you.
Heres what I have on a remote sensor arrangement.
It produces the following web page:
http://majestic81.plus.com/
This is the code that produces it , it has electricty consumption (all the stuff with 'blinks'), Dallas digital thermometer and analogue light level reading. It should give you some clues and you'll probably spot the code I lifted from the web server example......
 * Web Server
 * A simple web server that shows the value of the analog input pins.
#include <OneWire.h>
byte ip[] = { 192, 168, 0, 201 };
int ledPin = 0; // Pin 13 guzzled by ethernet
int dallasPin = 1;
int litePin = 0;
unsigned long time = 0;
unsigned long time1;
unsigned long mins = 60000;
unsigned long blinktime = 0;
unsigned long totalblinks = 0; // blinks since start
unsigned long blinksmin = 0; // blinks this minute
unsigned long blinkshour = 0; // blinks this Hour
unsigned long lastblink = 0;
unsigned long prevblink = 0;
unsigned long secs = 0;
unsigned long hrs = 3600000;
unsigned long elaphrs = 0;
unsigned long elapmin = 0;
byte dallasadd1[8];
byte data[8];
int i;
int dallas1;
float light;
int lite;
boolean lighton = false;
float watts1 = 0; // on elapsed time since last blink
float rollavwatts = 100;
float blinktimefloat = 0;
float temp1 = 0;
float temp = 0;
Server server(80);
OneWire  ds(dallasPin);
  Ethernet.begin(mac, ip);
  server.begin();
  pinMode(ledPin, OUTPUT);
  attachInterrupt(0, blink, RISING);
  ds.reset();
  ds.reset_search();
  ds.search(dallasadd1);
  ds.select(dallasadd1);
  ds.write(0x44,1);
  time = millis();
  elaphrs = int(time / 3600000);
  elapmin = elaphrs * 3600000;
  elapmin = time - elapmin;
  elapmin = elapmin / 60000;
  if (time >= secs){  // 1 second loop
     secs = time + 1000;
     blinktime = max(lastblink - prevblink,time - lastblink);
     blinktimefloat = float(blinktime) / 5;
     watts1 = 3600000 / blinktimefloat;
     ds.reset();
     ds.write(0xBE);         // Read Scratchpad
      for ( i = 0; i < 9; i++) { data[i] = ds.read(); };
     dallas1 = (data[1] << 8) + data[0];
     temp = float(dallas1);
     temp1 = temp/16;
     ds.reset();
     ds.write(0x44,1);
     lite = analogRead(0);
     light = float(light * 0.8 + lite * 0.2);
  if (time >= time1){  // 0.2 second loop
     time1 = time + 200;
      if (lighton){ digitalWrite(ledPin, HIGH); lighton = false; }
       else { digitalWrite(ledPin, LOW);};
   if (time >= mins){  // 1 minute loop
       mins = time + 60000;
       blinksmin = 0;
       rollavwatts = rollavwatts * 0.98 + watts1 * 0.02;
    if (time >= hrs){  // 1 Hour loop
     hrs = time + 3600000;
     blinkshour = 0;
  if (client) {
    // an http request ends with a blank line
    boolean current_line_is_blank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if we've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so we can send a reply
        if (c == '\n' && current_line_is_blank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println();
          client.println("Welcome to the Majestic Monitor");
          client.println("
          client.print("Milliseconds since start : ");
          client.print(time);
          client.println("
          client.print("Hours , Minutes since Start : ");
          client.print(elaphrs);
          client.print(" ");
          client.print(elapmin);
          client.println("
          client.print("Blinks Total , Last Min , Last Hour : ");
          client.print(totalblinks);
          client.print(" ");
          client.print(blinksmin);
          client.print(" ");
          client.print(blinkshour);
          client.println("
          client.print("Last Blink , Prev Blink, Last - Prev: ");
          client.print(lastblink);
          client.print(" ");
          client.print(prevblink);
          client.print(" ");
          client.print(lastblink-prevblink);
          client.println("
          client.print("Watts , Rolling Average Watts: ");
          client.print(watts1);
          client.print(" ");
          client.print(rollavwatts);
          client.println("
          client.print("Light Level: ");
          client.print(int(light));
          client.println("
          client.print("Digital Thermometer : ");
          client.print(temp1);
          client.print(" Deg C ");
          client.print(dallas1);
          client.print(" ");
          for( i = 0; i < 8; i++) {
            client.print(dallasadd1[i], HEX); client.print(" "); }
          client.println("
        if (c == '\n') {
          // we're starting a new line
        } else if (c != '\r') {
          // we've gotten a character on the current line
          current_line_is_blank = false;
    // give the web browser time to receive the data
    delay(1);
    client.stop();
void blink()
  if (lastblink - time > 500){
  lighton = true;
  prevblink = lastblink;
  lastblink = time;
  totalblinks ++;
  blinksmin ++;
  blinkshour ++;
Thank you very much Pluggy.
Actually what I want is to send a string from the command line through Telnet, and then retrieve a reply.
I cannot understand how client.read() and server.write() are working.
Thank you again.
m26k9,
One of the problems with using the telnet protocol is that there is handshaking that goes on between the client and server. The handshaking involves strings of bytes sent back and forth.
You should be able to work around this by using a different port than 23. Most telnet clients suppress the handshaking when using a port other than 23.
For example, change:
To:
Server server = Server(1023);
and when you start up the telnet client, type:
telnet 192.168.0.20 1023
Regards,
-Mike
Thanks heaps mfm9.
Changing the port worked perfectly. :slight_smile:
