(Beginner) Logic understanding problem for a toggle switch
Hi, I am trying to create a toggle switch with a pushbutton.
I have three variables:
int buttonOld=1;
int buttonNew;
String motState;
The input data (digitalRead(buttonPin)) for the pushbutton pin looks roughly like this:
111100011111000011110000....
where "0" is when I'm pressing the button and "1" is when the button is not being pushed.
I want motState to change each time I press the button.
For example going from "OFF" to "ON" or going from "ON" to "OFF".
So now I have tried to create a toggle switch with the following code:
void loop ( ) {
buttonNew=digitalRead(buttonPin);
if(buttonOld==0  &&  buttonNew==1){
  motState="ON";
if(buttonOld==0  &&  buttonNew==1 &&  motState="ON"){
   motState="OFF";
buttonOld=buttonNew;
What happens with the above code is that once I let go of the button
(buttonOld=0 and buttonNew=1)
then
motState="OFF"
and nothing changes if I press the button again.
I understand other ways of creating a toggle switch, however I would really want to know why THIS method does NOT work as this might help me gain some insight I'm clearly missing about the programming logic.
Every mechanical contact tends to bounce before it is 100% closed.
This is where debouncing helps.
Which Arduino? Which pin for button? How is button connected?
Post COMPLETE code.
Hi, sorry for the lack of complete info, this is my first time posting on the forum...
I am using the Arduino Uno board.
Button is connected as follows:
GND --> Button --> Pin 2.
Here is the complete code:
int buttonPin=2;
int buttonNew;
int buttonOld=1;
int DT=125;
String msg1="buttonOld: ";
String msg2=", buttonNew: ";
String msg3=", motState: ";
String motState;
pinMode(buttonPin,INPUT);
digitalWrite(buttonPin,HIGH);
Serial.print(msg1);
Serial.print(buttonOld);
Serial.print(msg2);
Serial.print(buttonNew);
delay(DT);
  motState="ON";
if(buttonOld==0 && buttonNew==1 && motState=="ON"){
  motState="OFF";
Serial.print(msg3),
Serial.println(motState);
what is debouncing?
Switch debouncing.
Read the forum guidelines to see how to properly post code.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Here is an example of toggling the state of a pin with a push button switch using the state change detection method. See also state change with an active low switch. You could, just as well, toggle the state of a bool variable.
// by C Goulding aka groundFungus
const byte  buttonPin = 4;    // the pin that the pushbutton is attached to
const byte ledPin = 13;       // the pin that the LED is attached to
bool buttonState = 0;         // current state of the button
bool lastButtonState = 0;     // previous state of the button
   // initialize the button pin as a input with internal pullup enabled
   pinMode(buttonPin, INPUT_PULLUP);
   // initialize the LED as an output:
   pinMode(ledPin, OUTPUT);
   // initialize serial communication:
   static unsigned long timer = 0;
   unsigned long interval = 50;  // check switch 20 times per second
   if (millis() - timer >= interval)
      timer = millis();
      // read the pushbutton input pin:
      buttonState = digitalRead(buttonPin);
      // compare the new buttonState to its previous state
      if (buttonState != lastButtonState)
         if (buttonState == LOW)
            // if the current state is LOW then the button went from off to on:
            digitalWrite(ledPin, !digitalRead(ledPin)); // toggle the output
      // save the current state as the last state,
      //for next time through the loop
      lastButtonState = buttonState;
Hi groundFungus,
Thank you for the help, but as I mentioned I am able to achieve my goal through different code but still want understand why the code I posted does not work for learning purposes.
-Einar
The way you've written your original code, once you assign buttonOld the value of 1, none of the if statements will ever be true.
The 2nd if statement will always be true when the first if statement is true, so as soon as you set motState to ON you immediately set it back to OFF.
