Beginner looking for programing help
Currently using:
Arduino Mega
ESP8266 adapter with ESP01 (Connected to D19 (RX1), D18 (TX1), 3.3V, and ground)
SD Card Reader (Connected to D50 (SPI - MISO), D51 (SPI - MOSI), D52 (SPI - SCK), D53 (SPI - SS), D54 (Ground)
Looking to figure out how I can remotely save files to the SD card to be read by the Arduino to control Pixels using XLIGHTS.
I am currently modifying FSEQPlayer.ino (code below) to fit my needs, but I only have basic knowledge of coding (C++) and completely new to Arduino programing. Eventually I would like to have the audio of the files played through a RF transmitter, but would like to at least figure out storage control via WiFi.
Questions:
Is this possible?
Where are the best resources to use to be able to understand editing this code better?
Any other recommendations?
Created:	9/18/2018 5:04:31 PM
Author:	Shaun Price
Contact:	Via Github website below
Copyright (C) 2018-2020 Shaun Price
Website:	https://github.com/ShaunPrice/FSEQLib
Version 2.0.0
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program.  If not, see <https://www.gnu.org/licenses/>.
SD Card VSPI PINS (ESP32 - Wemos Lolin32 Lite)
SCLK = 18
MISO = 19
MOSI = 23
SS = 5
SD Card SPI PINS (ESP8266 - Wemos D1 R2 mini)
SCLK = D5/GPIO 52
MISO = D6/GPIO 50
MOSI = D7/GPIO 51
SS   = D8/GPIO 53
Also note Card Detect (CD) and Data Pin defines.
#ifdef ESP8266
#include <SDFSFormatter.h>
#include <SDFS.h>
#endif
#include <SPI.h>
#include <SD.h>
#include <FastLED.h>
#include "FSEQLib.h"
#define DEBUG 0 // 0=OFF, 1=Serial
// Serial Debug Info
#if (DEBUG == 1)
#define SERIAL_BEGIN(x) Serial.begin(x)
#define DEBUG_PRINT(x) Serial.print(x)
#define DEBUG_PRINTLN(x) Serial.println(x)
#else
#define DEBUG_PRINT
#endif
#ifdef ESP8266
// ESP8266
#define DATA_PIN_1 4			// Data pin for universe 1. // D2 - Wemos D1 R2 mini
#define CARD_DETECT_PIN  0		// May require 10k pull-up  // D3 - Wemos D1 R2 mini
#else
// ESP32
#define DATA_PIN_1 13			// Data pin for universe 1.
#define CARD_DETECT_PIN  17		// May require 10k pull-up
#endif
// This is where the second universe would go if using more than one universe
//#define DATA_PIN_2 14	// Data pin for universe 2.
#define FSEQ_FILE "/show.dat"	// Name of the FSEQ file to play
#define UNIVERSES 1				// Universes aren't really defined here but I use the term to define the
								//  number of times I want to split up the sequence step channels into.
#define NUM_NODES 150			// Nodes/Pixels
#define NUM_CHANNELS_PER_NODE 3 // Number of channels/LEDs per Node/Pixel
#define LEDS_PER_UNIVERSE NUM_NODES * NUM_CHANNELS_PER_NODE	// LEDs/channels per universe
#define BUFFER_LENGTH (UNIVERSES * LEDS_PER_UNIVERSE) + ((4 - (UNIVERSES * LEDS_PER_UNIVERSE) % 4) % 4) // Buffer is 32 bit (4 byte) padded.
// Adjust the brightness of the display
// For best results leave brightness at 255 (100%)
// and correct the brightness with Xlights.
#define BRIGHTNESS 255
size_t bytesRead = 0;
File dataFile;
// SPI
char stepBuffer[BUFFER_LENGTH];
CRGB leds[UNIVERSES][NUM_NODES];
//uint8_t universeBuffer[LEDS_PER_UNIVERSE]; // If using uint8_t buffer rather than CRGB buffer
uint32_t sequenceDelay = 50; // This will get set from the FSEQ header
int32_t currentStep = 0;
HeaderData rawHeader;
FSEQLib header;
bool cardInitialised = false;
bool cardDetected = false;
	SERIAL_BEGIN(115200);
	pinMode(SS, OUTPUT); // SD Card VSPI SS
	pinMode(CARD_DETECT_PIN, INPUT_PULLUP); // SD Card Detected CD
	FastLED.addLeds<NEOPIXEL, DATA_PIN_1>(leds[0], NUM_NODES);
	// The second universe would be:
	//FastLED.addLeds<NEOPIXEL, DATA_PIN_2>(leds[1], NUM_NODES);
	FastLED.setBrightness(BRIGHTNESS);
	unsigned long startMillis = millis();
	cardDetected = (digitalRead(CARD_DETECT_PIN) == 1) ? true : false;
	// Initialise SPI Master
	// See if the card is present and can be initialized:
	if (cardDetected && !cardInitialised)
		DEBUG_PRINTLN("Initializing SD card...");
		//SDFS.setConfig(SDFSConfig(SS));
		if (SD.begin(SS))
			DEBUG_PRINTLN("card initialized.");
			// Open the file.
			// Note that only one file can be open at a time,
			// so you have to close this one before opening another.
			// Also, this only supports 8.3 format so we need to
			// rename the file from xxx.fseq to something else.
			dataFile = SD.open(FSEQ_FILE, "r");
			DEBUG_PRINTLN("File size: " + String(dataFile.size()));
			if (dataFile.size() > 0)
				cardInitialised = true;
				dataFile.readBytes(rawHeader.rawData, 28);
				header = FSEQLib(rawHeader);
				// DEBUG code to print out the header details
				if (header.majorVersion() == 1)
					DEBUG_PRINTLN( "======================");
					DEBUG_PRINTLN( "== Xlights FSEQ V1.0 Header");
					DEBUG_PRINTLN( "Magic: " + String(header.magic()));
					DEBUG_PRINTLN( "Data Offset: " + String(header.dataOffset()));
					DEBUG_PRINTLN( "Version: " + String(header.majorVersion()) + "." + String(header.minorVersion()));
					DEBUG_PRINTLN( "Header Length: " + String(header.headerLength()));
					DEBUG_PRINTLN( "Channels per Step: " + String(header.channelsPerStep()));
					DEBUG_PRINTLN( "Number of Steps: " + String(header.sequenseSteps()));
					DEBUG_PRINTLN( "Step Time (ms): " + String(header.stepTime()));
					DEBUG_PRINTLN( "Universes: " + String((header.universes() == 0) ? 0 : header.universes()));
					DEBUG_PRINTLN( "Size of Universe: " + String((header.sizeofUniverses() == 0) ? 0 : header.sizeofUniverses()));
					DEBUG_PRINTLN( "Gamma: " + String(header.gamma()));
					DEBUG_PRINTLN( "Color Order: " + header.colorOrder());
					DEBUG_PRINTLN("======================");
					DEBUG_PRINTLN("== Xlights FSEQ V2.0 Header");
					DEBUG_PRINTLN( "Magic: " + header.magic());
					DEBUG_PRINTLN( "Step Time (ms): " + String(header.stepTime()));					DEBUG_PRINTLN( "Compression Type: " + header.compressionTypeName());
					DEBUG_PRINTLN( "Compressed Blocks: " + String(header.compressedBlocks()));
					DEBUG_PRINTLN( "Sparse Ranges: " + String(header.sparseRanges()));
					DEBUG_PRINTLN( "UUID: " + String((char)header.uuid()));
				DEBUG_PRINTLN("done!");
				// Set the data offset
				dataFile.seek(header.dataOffset());
				sequenceDelay = header.stepTime();
				dataFile.close();
			DEBUG_PRINTLN("Card failed, or not present");
	else if (!cardDetected && cardInitialised)
		DEBUG_PRINTLN("Card removed");
		dataFile.close();
	else if (cardDetected && cardInitialised)
		// Read the channels for the next step
		int datalen = dataFile.readBytes(stepBuffer, BUFFER_LENGTH);
		if (datalen != BUFFER_LENGTH)
			DEBUG_PRINTLN("Buffer Failed to load. Closing File and SD card");
			dataFile.close();
			// Output data
			for (uint8_t current_universe = 0; current_universe < UNIVERSES; current_universe++)
				// Copy the led values into the universe buffer
				memcpy(&leds[current_universe], &stepBuffer[current_universe * LEDS_PER_UNIVERSE], LEDS_PER_UNIVERSE);
				//memcpy(&universeBuffer[0], &stepBuffer[current_universe * LEDS_PER_UNIVERSE], LEDS_PER_UNIVERSE); // If using uint8_t buffer rather than CRGB buffer
				// Send the data
				FastLED.show();
			currentStep++;
			// Reset to first step if we have gone past the last step
			if (currentStep == header.sizeofUniverses())
				// Restart at first step
				currentStep = 0;
				// Restart file after header
				//Corrected offset starting point or it will overlap with multiple universes
	// Delay to make sure we send the number of times specified per second.
	// The delay is constrained between 1ms and 50ms
	delay(constrain(sequenceDelay - (millis() - startMillis), 1, 50));
Please produce real schematics. Words doesn't give the overview needed for precise answers.
Did you test the original code to be sure it works with your components?
The sketch compiles in Arduino IDE, & seems to be working. I have not attached pixels to the data pin as of yet.
