Beginner problem with keyboard code
Hi, I have searched on google and in the forum for a couple of hours now, and I can't seem to find anything that solves my problem. (atleast anything I understand)
I have just started using ARDUINO. So this is my first attempt at C++ Coding. I am pretty good at electronics, but I have never used codes except for macros in Excel.
What Im trying to do:
I want to make a "log point" button for a GPS in an excavator. It is basically really simple. I need a button that does the same as if I connect a USB keyboard to the GPS screen. It only need to Press "F7" and wait half a second and then press "Enter" or "ESC"
I use the ANDRUINO Pro Mini board, and is is all wired up with button and USB cable (USB to GPS Screen). I believe it should work!
My problem is the coding. to make it short:
My code needs to "tell" the GPS it is a USB keyboard and then press F7 followed by Enter or ESC
My Code so far:
// Require keyboard control library
#include <KeyboardController.h>
#include "Arduino.h"
// Initialize USB Controller
USBHost usb;
// Attach keyboard controller to USB
KeyboardController keyboard(usb);
// This function intercepts key press
void keyPressed() {
  Serial.print("Pressed: KEY_F7 ");
  Serial.print("Pressed: KEY_ESC ");
  printKey();
// This function intercepts key release
void keyReleased() {
  Serial.print("Released: ");
  printKey();
void printKey() {
  // getOemKey() returns the OEM-code associated with the key
  Serial.print(" key:");
  Serial.print(keyboard.getOemKey());
  // getModifiers() returns a bits field with the modifiers-keys
  int mod = keyboard.getModifiers();
  Serial.print(" mod:");
  Serial.print(mod);
  Serial.print(" => ");
  if (mod & LeftCtrl)
    Serial.print("L-Ctrl ");
  if (mod & LeftShift)
    Serial.print("L-Shift ");
  if (mod & Alt)
    Serial.print("Alt ");
  if (mod & LeftCmd)
    Serial.print("L-Cmd ");
  if (mod & RightCtrl)
    Serial.print("R-Ctrl ");
  if (mod & RightShift)
    Serial.print("R-Shift ");
  if (mod & AltGr)
    Serial.print("AltGr ");
  if (mod & RightCmd)
    Serial.print("R-Cmd ");
  // getKey() returns the ASCII translation of OEM key
  // combined with modifiers.
  Serial.write(keyboard.getKey());
  Serial.println("Program started");
  delay(200);
  // Process USB tasks
  usb.Task();
I have just copied one of the exaples in the Arduino 1.5.6-r2 BETA program and filled in what I atleast think I should do.
I leave the sentences with // in place just so I can get a better understanding of what the different codes do!
When i try to verify it i get the error message: Compiling error (or something similar since I get in it Norwegian)
Copy of error message:
Arduino:1.5.6-r2 (Windows 7), Kort"Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
WARNING: library USBHost claims to run on [sam] architecture(s) and may be incompatible with your current board which runs on [avr] architecture(s).
In file included from C:\Program Files (x86)\Arduino\libraries\USBHost\src/KeyboardController.h:22,
                 from sketch_may14a.ino:2:
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h: In member function 'virtual void HIDBoot<BOOT_PROTOCOL>::EndpointXtract(uint32_t, uint32_t, uint32_t, uint32_t, const USB_ENDPOINT_DESCRIPTOR*)':
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h:474: error: 'UOTGHS_HSTPIPCFG_PTYPE_INTRPT' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h:474: error: 'UOTGHS_HSTPIPCFG_PTOKEN_IN' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h:474: error: 'UOTGHS_HSTPIPCFG_PBK_1_BANK' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h:474: error: there are no arguments to 'UHD_Pipe_Alloc' that depend on a template parameter, so a declaration of 'UHD_Pipe_Alloc' must be available
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h:474: error: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated)
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h: In member function 'virtual uint32_t HIDBoot<BOOT_PROTOCOL>::Release()':
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h:500: error: there are no arguments to 'UHD_Pipe_Free' that depend on a template parameter, so a declaration of 'UHD_Pipe_Free' must be available
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h: In member function 'uint32_t HIDBoot<BOOT_PROTOCOL>::Release() [with unsigned char BOOT_PROTOCOL = 1u]':
sketch_may14a.ino:72:   instantiated from here
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h:500: error: 'UHD_Pipe_Free' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h: In member function 'void HIDBoot<BOOT_PROTOCOL>::EndpointXtract(uint32_t, uint32_t, uint32_t, uint32_t, const USB_ENDPOINT_DESCRIPTOR*) [with unsigned char BOOT_PROTOCOL = 1u]':
C:\Program Files (x86)\Arduino\libraries\USBHost\src/hidboot.h:474: error: 'UHD_Pipe_Alloc' was not declared in this scope
  Denne rapporten vil inkludere mer informasjon med
  "Vis detaljert informasjon under kompilering"
  enabled in File > Preferences.
And remember I am completely new to C++ coding, so I guess Ill have to check half the words/expressions you guys use up in a dictionary!
Any help will be apreciated! :slight_smile:
The Pro Mini uses a ATmega328 which has no USB...
That library appears to be designed for the Due?
there is no micro USB port on the Pro Mini card, but I have soldered a USB cable to the outputs I want to use. (Very likely I have missed completely on the code!)
I was pretty sure it was possible to get it to work this way. But should I use another "example" to build my code upon?
How the wiring is done/supposed to be done:
USB Cable: Arduino card:
Red 5V
Green D3
White D2
Black GND
Pulse switch: Arduino card:
Black D4
Red 5V
123? restisance: Arduino:
1 D4
2 GND
The resistance I got told to put in there to avoid the "input" to be high after releasing the button.
No, you've missed something on the hardware. The Arduino you have is not capable of announcing itself as a keyboard. Get a Leonardo or a Micro, which can, or a Teensy which is probably better for your purposes (it really is teensy).
