Beginner Question about what Voltage to supply to LED driver.
Hello everyone,
I belive this probably is a very simple question, but all researching online has not brought up anything I would understand.
So:
I would like to build my own little dimmable underwater lighting system with a Cree high power LED
THIS is the LED I want to use.
Now, I know I need a driver that has an PWM input so I can dimm it with the arduino.
I thought about using THIS LED driver.
Now my only real question is the following:
Lets say the single color LED need 3.4V and a current of 700mA. If I use 2 I still have 700mA and 6.8V
I need to run the system on my 12V board system - can I just use anything from 11-14.5V strait into the MeanWell driver as long as my input voltage is higher than the sum of single voltages of the LEDs in row? Can I still give it a 100% working cycle or do would that mean the LEDs will receive whatever I have as input voltage?
I know this may seem a very stupid question, but I would really appreciate a brief explanation.
Thanks!
Great job supplying us with the product :slight_smile: Most newbie "forget".
Sme_1986:
If you can place the leds in series, yes. And it looks like this module has anode and cathode of each light broken out (6 wires) so you can.
Sme_1986:
Yes. Or even better, up to 56V isn't a problem for the driver.
Sme_1986:
You can, the driver will limit the current to the max current. Don't think about controlling leds with a voltage. You set a current and the voltage is just a result of the applied current. The mentioned 3,4V is just a estimate of the voltage when you apply 700mA so you know what voltage you need to at least supply to the driver (+ the difference due to inefficiency) and the driver will limit the current thus knocking down the voltage (because it's a step down type it can only increase the voltage).
Thanks a lot for your great reply. This finally answered all my questions!
Perfect :slight_smile:
