I rarely do something so intelligent as to check on a project before I actually start buying things and realize I've bit off too much. I have very little experience in circuitry but I can probably handle the programming side. I wanted to check on a project idea. It looks like Arduino can do things like this but I wanted to check and see how difficult this idea would be:
I want to make a set of devices that works like this:
Point A: Arduino + IR Motion Sensor
Point B: Light
Arduino + IR motion sensor is used to activate a remote lighting object. It looks like I can easily make a motion sensor, but can I create a device where the Arduino is housed at point A and when the IR motion sensor is activated, the light at Point B is turned on? This would be a wireless light object. The idea is really simple, but I don't know what would be needed to make this a reality.
Questions:
Using a method of wireless communication, can I use WiFi or some sort of radio signal?
Would both objects need to be Arduinos or could one be a much smaller device?
Much thanks to any responses
