Beginner here, pretty much completely new to all things Arduino.
Anyway, I'm using the sparkfun microSD card shield (SparkFun microSD Shield - DEV-12761 - SparkFun Electronics) and attempting to interface with an Arduino Zero, just as a simple data logger as a part of a project. I get a card initialization error every time I attempt to open it.
Are there any issues using the SD card library with an Arduino Zero? The code I have has the chip select set to 8, as I believe it is supposed to be.
I'm using this SD card: http://www.amazon.com/Samsung-Class-Adapter-MB-MP16DA-AM/dp/B00IVPU7KE, not sure if that's the issue here.
Thanks for any help, sorry that I can't provide any more information; like I said, completely new to this whole thing and don't have a great understanding of SPI and such.
Code:
//USES SD CARD LIBRARY TO INITALIZE SD CARD, Serial lines used for debugging purposes
void initializeSD()
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(8)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
