Beginner questions: Using the MCP4261 library
Look in my code that is modified from the example. I put the pin out and connections in the code. It worked for me.
If you need more information let us know.
// This example demonstrates control over SPI to the Microchip McpDigitalPot Digital potentometer mcp42xxx family
// SPI Pinouts are for Arduino Uno and Arduino Duemilanove board (will differ for Arduino MEGA)
/*mcp42xxx family
///////////////////////commands from data sheet////////////////
00000000 to write to pot 2
00010000 to write to pot 1 /////////////32?
11 Read Data 16-Bits
00 Write Data 16-Bits
01 Increment 8-Bits
10 Decrement 8-Bits
////////////////////////////Chip pins////////////////////////
1  -CS to DIGITAL PIN 10 (same as latch)
2  -SCK to DIGITAL PIN 13 (clock)
3  -SDI to DIGITAL PIN 11 (data IN)
4  -VSS GROUND
5  -P1B GROUND
6  -P1W (channel 2 wiper)
7  -P1A +5V
8  -P0A +5v
9  -P0W (channel 1 wiper)
10 -P0B GROUND
11 -WP on mine +5v, good luck
12 -SHDN +5v
13 -SDO to DIGITAL PIN 12 (data OUT)
14 -VDD +5v
//////////////////////////////////////////information sources///////////////////////////
Base code and library came from here https://github.com/teabot/McpDigitalPot
http://pdf1.alldatasheet.com/datasheet-pdf/view/306650/MICROCHIP/MCP4251-502E/MS.html
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1269918888/all
#include <SPI.h>
// McpDigitalPot library available from https://github.com/dreamcat4/McpDigitalPot
#include <McpDigitalPot.h>
// Wire up the SPI Interface common lines:
// #define SPI_CS               10 //arduino   <->   SPI Chip Select           -> CS  (Pin 01 on McpDigitalPot DIP)
// #define SPI_CLOCK            13 //arduino   <->   SPI Slave Clock Input     -> SCK (Pin 02 on McpDigitalPot DIP)
// #define SPI_MOSI             11 //arduino   <->   SPI Master Out Slave In   -> SDI (Pin 03 on McpDigitalPot DIP)
// #define SPI_MISO             12 //arduino   <->   SPI Master In Slave Out   -> SDO (Pin 13 on McpDigitalPot DIP)
// Then choose any other free pin as the Slave Select (pin 10 if the default but doesnt have to be)
#define MCP_DIGITAL_POT_SLAVE_SELECT_PIN 10 //arduino   <->   Chip Select               -> CS  (Pin 01 on McpDigitalPot DIP)
// Its recommended to measure the rated end-end resistance (terminal A to terminal B)
// Because this can vary by a large margin, up to -+ 20%. And temperature variations.
float rAB_ohms = 10000.00; // 10k Ohm
float rW_ohms  = 94;       // 94 Ohm
// Instantiate McpDigitalPot object, with default rW (=117.5 ohm, its typical resistance)
//McpDigitalPot digitalPot = McpDigitalPot( MCP_DIGITAL_POT_SLAVE_SELECT_PIN, rAB_ohms );
// rW - Wiper resistance. This is a small additional constant. To measure it
// use the example, setup(). Required for accurate calculations (to nearest ohm)
// Datasheet Page 5, gives typical values MIN=75ohm, MAX @5v=160ohm,@2.7v=300ohm
// Usually rW should be somewhere between 100 and 150 ohms.
// Instantiate McpDigitalPot object, after measuring the real rW wiper resistance
 McpDigitalPot digitalPot = McpDigitalPot( MCP_DIGITAL_POT_SLAVE_SELECT_PIN, rAB_ohms, rW_ohms );
   Serial.begin(57600);
  // initialize SPI:
  SPI.begin();
  // First measure the the wiper resistance, called rW
  digitalPot.setPosition(0, 0); // rAW = rW_ohms
  digitalPot.setPosition(1, 0); // rAW = rW_ohms
  //delay(5000);
  // (optional)
  // Scale to 100.0 for a percentage, or 1.0 for a fraction
  // Eg if scale=100, then setResistance(0, 100) = max rAW resistance
  // Eg    scale=1.0, then setResistance(0, 1.0) = max rAW resistance
  // digitalPot.scale = 1.0;
  digitalPot.scale = 100.0; // For the timeout example, below
  // digitalPot.setResistance(0, 40); // set pot0 rAW = 40% of max value
  // digitalPot.setResistance(1, 80); // set pot1 rAW = 80% of max value
  // delay(5000);
  // digitalPot.setResistance(0, 5);  // set pot0 rAW =  5% of max value
  // digitalPot.setResistance(1, 50); // set pot1 rAW = 50% of max value
  // Go back to using ohms
  // digitalPot.scale = McpDigitalPot.rAB_ohms;
// Cycle the wipers around at 20% increments, changing every 2 seconds
long timeoutInterval = 200;
long previousMillis = 0;
float counter = 0.0;
void timeout()
  if(counter > 100.0)
    counter = 0.0;
  // These resistances are just percentages of 100
  digitalPot.setResistance(0, 100 - counter);
  digitalPot.setResistance(1,  counter); // Invert the wiper1
  counter += 1.0;
  if (  millis() - previousMillis > timeoutInterval )
    timeout();
    previousMillis = millis();
    Serial.print((counter - 20) * 100);
    Serial.println("ohms");
  // Loop.
