Hi, I am trying to write some code for a project to move a stepper motor whenever one of 4 buttons is pressed. Each button is laid 90 degrees apart around the motor in a circle, the motor will essentially point to the button that has been pressed and then to the next one that is pressed etc. (I will later swap the buttons for sensors but for now I am just using buttons)
Could someone show me an example code for how this could be done? I expect I will need to do some if/else logic and set up states for each different movement but I am not exactly sure what this would look like.
Also, when the stepper is turning 180 degrees I would like to make is random whether it goes clockwise or anticlockwise, how would I do this?
And how can I make the motor know which position it is pointing in upon startup so that it isn't out of sync?
I am using a 200 step 2 phase motor (https://www.sparkfun.com/products/9238)
and an Uno with an adafruit motorshield V2 (Adafruit Motor/Stepper/Servo Shield for Arduino v2 Kit [v2.3] : ID 1438 : $19.95 : Adafruit Industries, Unique & fun DIY electronics and kits)
Here is the code I am starting with, it is working fine to move the stepper so far:
StepperCode.ino (1.2 KB)
