Beginner
I am a complete beginner with all this so before I get too involved I would like to ask a simple question if I may.
Once I have developed a device using the Arduino project board how do I then translate that into a permanenet working device.
Is there any advice/guidance on how to make a permanent unit thus releasing the Arduino board for future projects or is that it, do I have to use the board in the permanent device and so have to buy another Arduino to make something else?
There is plenty of advice on this forum, including pictures as to:
  • put a standalone processor with external components onto a breadboard*
  • burn a standalone processor with various devices (including the arduino itself, cheap serial programmers & parallel programmers)
    There is a whole subforum on that topic.
  • change the "fuse settings" to use different external components such as a crystal, a resonator, or the MCUs own internal clock.
I would advise you to carry on with the Arduino for now, and buy a couple of the MCU chips, initially with a bootloader ( a few pounds off ebay), or without and burn your own bootloader, then rig them up on a breadboard.
If you are only making a few items it might be cost effective to just use Arduino boards with a shield or external circuit.
*(minimally processor, C and R for reset, 2C and a crystal for timing; I tend to put a MAX202 chip + 5C on the board too so that I can program it using a USB-Serial adaptor)
Welcome to Arduino.
My steps are the following.
First I get the project working, then transfer it to a breadboard.
Finally if I am going to put it someplace permanent I then solder up a standalone version.
I like using the Adafruit proto boards for this.
I have also used an RBB Pro in permanent projects as well, instead of making a stand alone Arduino. They are cheaper than something like the Arduino Uno and smaller.
http://shop.moderndevice.com/products/rbbb-pro
