Beginners different types Feather M0 RFM69
Hello dear forum,
I connected 2x Father M0 RFM69 via radio.
I want to read the battery voltage at the transmitter.
In the transmitter, I sent analog read directly to the receiver via radio, in the receiver it should convert the value.
It was very difficult for me to send only the analog value to the transmitter because I do not understand the types uint8, sizeof, char and so on.
I ask for your help. at the receiver is the problem that he receives the value but I can not convert to volt.
Here is the station code I got from RadioHead69_RawDemo_TX
// rf69 demo tx rx.pde
// -*- mode: C++ -*-
#include <SPI.h>
#include <RH_RF69.h>
char Sensor1CharMsg[21];
/************ Radio Setup ***************/
// Change to 434.0 or other frequency, must match RX's freq!
#define RF69_FREQ 915.0
//Akku pin
#define VBATPIN A7
#if defined (__AVR_ATmega32U4__) // Feather 32u4 w/Radio
#define RFM69_CS      8
#define RFM69_INT     7
#define RFM69_RST     4
#define LED           13
#endif
#if defined(ADAFRUIT_FEATHER_M0) // Feather M0 w/Radio
#define RFM69_CS      8
#define RFM69_INT     3
#define RFM69_RST     4
#define LED           13
#endif
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);
int16_t packetnum = 0;  // packet counter, we increment per xmission
  //while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer
  pinMode(LED, OUTPUT);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);
  Serial.println("Feather RFM69 TX Test!");
  // manual reset
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  delay(10);
  if (!rf69.init()) {
    Serial.println("RFM69 radio init failed");
    while (1);
  Serial.println("RFM69 radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ)) {
    Serial.println("setFrequency failed");
  // If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
  // ishighpowermodule flag set like this:
  rf69.setTxPower(14, true);  // range from 14-20 for power, 2nd arg must be true for 69HCW
  // The encryption key has to be the same as the one in the server
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
  rf69.setEncryptionKey(key);
  Serial.print("RFM69 radio @");  Serial.print((int)RF69_FREQ);  Serial.println(" MHz");
  delay(1000);  // Wait 1 second between transmits, could also 'sleep' here!
  sprintf(Sensor1CharMsg, "%d", analogRead(VBATPIN));
  Serial.print("Sending "); Serial.println(Sensor1CharMsg);
  rf69.send((uint8_t *)Sensor1CharMsg, strlen(Sensor1CharMsg));
  rf69.waitPacketSent();
  // Now wait for a reply
  uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  if (rf69.waitAvailableTimeout(500))  {
    // Should be a reply message for us now
    if (rf69.recv(buf, &len)) {
      Serial.print("Got a reply: ");
      Serial.println((char*)buf);
      Blink(LED, 50, 3); //blink LED 3 times, 50ms between blinks
      Serial.println("Receive failed");
    Serial.println("No reply, is another RFM69 listening?");
void Blink(byte PIN, byte DELAY_MS, byte loops) {
  for (byte i = 0; i < loops; i++)  {
    digitalWrite(PIN, HIGH);
    delay(DELAY_MS);
    digitalWrite(PIN, LOW);
    delay(DELAY_MS);
Here is the recipient of RadioHead69_RawDemo_RX.
Line 134 unsigned char measuredvbat … I can’t get any further :frowning:
#include <SPI.h>
#define RFM69_CS      8
#define RFM69_INT     7
#define RFM69_RST     4
#define LED           13
#endif
#define RFM69_CS      8
#define RFM69_INT     3
#define RFM69_RST     4
#define LED           13
#endif
  Serial.println("Feather RFM69 RX Test!");
  // manual reset
  delay(10);
  delay(10);
  if (!rf69.init()) {
    while (1);
  // No encryption
  if (rf69.available()) {
    // Should be a message for us now
      if (!len) return;
      buf[len] = 0;
      Serial.print("Received [");
      Serial.print(len);
      Serial.print("]: ");
      Serial.print("RSSI: ");
      Serial.println(rf69.lastRssi(), DEC);
      //unsigned char measuredvbat = char(buf);
      //      Serial.println(measuredvbat);
      //      measuredvbat *= 2;    // we divided by 2, so multiply back
      //      measuredvbat *= 3.3;  // Multiply by 3.3V, our reference voltage
      //      measuredvbat /= 1024; // convert to voltage
      if (strstr((char *)buf, "Hello World")) {
        // Send a reply!
        uint8_t data[] = "And hello back to you";
        rf69.send(data, sizeof(data));
        Serial.println("Sent a reply");
        Blink(LED, 40, 3); //blink LED 3 times, 40ms between blinks
    delay(DELAY_MS);
    delay(DELAY_MS);
I am very grateful for any help
Merry Christmas
Markylein: It was very difficult for me to send only the analog value to the transmitter because I do not understand the types uint8, sizeof, char and so on.
Very fundamental to using Arduinos, for any application, is to undestand the basics of variable types.
There must be gazillions of tutorials out there on the Intenet on this sort of stuff, even 'books'.
