beginner's error
Hi guys,
I have a problem with brackets on a program that will allow me to manage the speed of a motor using a potentiometer so I would like to have help to finish this program:
char PWM_ENABLE = 3;
char D0_MOTOR_1 = 2;
char D0_MOTOR_2 = 4;
char AN_POTENTIOMETRE = A0;
int valeurPotentiometre = 0;
int vitesseDuMoteur = 0;
pinMode(D0_MOTOR_1, OUTPUT);
pinMode(D0_MOTOR_2, OUTPUT);
pinMode(PWM_ENABLE, OUTPUT);
digitalWrite(D0_MOTOR_1, LOW);
digitalWrite(D0_MOTOR_2, LOW);
analogWrite(PWM_ENABLE, OUTPUT);
valeurPotentiometre = analogRead(AN_POTENTIOMETRE);
if(valeurPotentiometre > 512)
digitalWrite(D0_MOTOR_2, HIGH);
vitesseDuMoteur = map(valeurPotentiometre, 512, 1023, 0, 255);
Serial.print("+");
digitalWrite(D0_MOTOR_1, HIGH);
vitesseDuMoteur = map(valeurPotentiometre, 0, 512, 255, 0);
Serial.print("-");
analogWrite(PWM_ENABLE, vitesseDuMoteur);
Serial.println(vitesseDuMoteur);
delay(20);
I have this error message : “expected ‘)’ before ‘;’ token” for the first digitalWrite of the void loop
I have try different thing without success so i need your help :smiley:
( and ) should be { and }
You put parentheses around your if and else blocks. Those should be brackets.
You can read all about it in the reference section: if - Arduino Reference
Firstly, compound statements in C++ use {}, not ().
Secondly, your pin number variables should probably be declared const. That way they will not occupy data memory at all.
Montmorency:
That is NOT the primary reason for using const. The primary reason is so that you don't accidentally use a variable containing a pin number on the left of an equal sign, where you meant to use a variable containing a pin state.
PaulS:
Theres no such thing as "primary" or "non primary" use of const. In general, it is always a good idea to follow the rules of const-correctness. And the benefits of that are numerous.
In C++ (as opposed to C) a major feature of const is that it produces compile-time constants: entities that are known at compile time and that don"t materialize as lvalues unless you really want them to. This is already a very nice and important feature.
In fact, since we are talking about C++ code specifically, a better fit for this context would be constexpr.
