I am puzzled by the second and third of the three constant definitions at the beginning of the HelloWorld sketch in chap 2, listing 2.7 of "Beginning Android ADK with Arduino" by Mario Bohmer which are Hex, for some reason, while the first is decimal. Why?
In the book's text he writes about messages being 3-byte long byte arrays e.g., command - target - value, but confusingly has a diagram with, for instance, the command byte labelled with 0xF ???! However, I understand one byte = 8 bits, 0-255 but 0xF is Hex for 15???
Sorry I am thick - please explain. No way to contact author
#include <Max3421e.h>
#include <Usb.h>
#include <AndroidAccessory.h>
#define ARRAY_SIZE 25
#define COMMAND_TEXT 0xF
#define TARGET_DEFAULT 0xF
AndroidAccessory acc("Manufacturer",
"Model",
"Description",
"Version",
"URI",
"Serial");
char hello[ARRAY_SIZE] = {'H','e','l','l','o',' ',
'W','o','r','l','d',' ', 'f', 'r', 'o', 'm', ' ',
'A', 'r', 'd', 'u', 'i', 'n', 'o', '!'};
byte rcvmsg[255];
byte sntmsg[3 + ARRAY_SIZE];
acc.powerOn();
if (acc.isConnected()) {
//read the sent text message into the byte array
int len = acc.read(rcvmsg, sizeof(rcvmsg), 1);
if (len > 0) {
if (rcvmsg[0] == COMMAND_TEXT) {
if (rcvmsg[1] == TARGET_DEFAULT){
//get the textLength from the checksum byte
byte textLength = rcvmsg[2];
int textEndIndex = 3 + textLength;
//print each character to the serial output
for(int x = 3; x < textEndIndex; x++) {
Serial.print((char)rcvmsg[x]);
delay(250);
delay(250);
sntmsg[0] = COMMAND_TEXT;
sntmsg[1] = TARGET_DEFAULT;
sntmsg[2] = ARRAY_SIZE;
for(int x = 0; x < ARRAY_SIZE; x++) {
sntmsg[3 + x] = hello[x];
acc.write(sntmsg, 3 + ARRAY_SIZE);
delay(250);
