// Project 42
// Based on the SD Fat examples by Bill Greiman from sdfatlib
#include <SdFat.h>
#include <SdFatUtil.h>
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
// Write a Carriage Return and Line Feed to the File
void writeCRLF(SdFile& f) {
f.write((uint8_t*)"\r\n", 2);
// Write an unsigned number to file
void writeNumber(SdFile& f, uint32_t n) {
uint8_t buf[10];
uint8_t i = 0;
do {
i++;
buf[sizeof(buf) - i] = n%10 + '0';
n /= 10;
} while (n);
f.write(&buf[sizeof(buf) - i], i);
// Write a string to file
void writeString(SdFile& f, char *str) {
uint8_t n;
for (n = 0; str[n]; n++);
f.write((uint8_t *)str, n);
Serial.println("Type any character to start");
while (!Serial.available());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with breadboards.
// Use SPI_FULL_SPEED for better performance if your card can take it.
if (!card.init(SPI_HALF_SPEED)) error("card.init failed");
// initialize a FAT volume
if (!volume.init(&card)) error("volume.init failed");
// open the root directory
if (!root.openRoot(&volume)) error("openRoot failed");
// create a new file
char name[] = "TESTFILE.TXT";
file.open(&root, name, O_CREAT | O_EXCL | O_WRITE);
// Put todays date and time here
file.timestamp(2, 2012, 06, 07, 24, 00, 00);
// write 10 lines to the file
for (uint8_t i = 0; i < 10; i++) {
writeString(file, "Line: ");
writeNumber(file, 1);
writeString(file, " Write test.");
writeCRLF(file);
// close file and force write of all data to the SD card
file.close();
Serial.println("File Created");
// open a file
if (file.open(&root, name, O_READ)) {
Serial.println(name);
else{
error("file.open failed");
int16_t character;
while ((character = file.read()) > 0) Serial.print((char)character);
Serial.println("\nDone");
void loop() {}
