begintimer and endtimer won't change value
Hello,
The begintimer and eindtimer (endtimer) won't change their values to now()
I don't know what causes this
To set the time im using Setserial by JChristensen
Here's my code
#include <DS3232RTC.h>      // https://github.com/JChristensen/DS3232RTC
#include <Streaming.h>      // http://arduiniana.org/libraries/streaming/
#define licht A1 //Lichtsensor krijgt analoge pinwaarde A1
int relais_licht = 4;
unsigned long begintimer = 0;
unsigned long eindtimer = 0;
unsigned long aantal_uren_zonlicht = 0;
unsigned long previousTime_licht = 0;
const byte interval_licht = 10; // dit is 10 seconden
const byte som_waarde = 29;
boolean flag_bijbelichting = false;
    // setSyncProvider() causes the Time library to synchronize with the
    // external RTC by calling RTC.get() every five minutes by default.
    setSyncProvider(RTC.get);
    Serial << F("RTC Sync");
    if (timeStatus() != timeSet) Serial << F(" FAIL!");
    Serial << endl;
      pinMode(relais_licht, OUTPUT);
   lichtsysteem();
    static time_t tLast;
    time_t t;
    tmElements_t tm;
    // check for input to set the RTC, minimum length is 12, i.e. yy,m,d,h,m,s
    if (Serial.available() >= 12) {
        // note that the tmElements_t Year member is an offset from 1970,
        // but the RTC wants the last two digits of the calendar year.
        // use the convenience macros from the Time Library to do the conversions.
        int y = Serial.parseInt();
        if (y >= 100 && y < 1000)
            Serial << F("Error: Year must be two digits or four digits!") << endl;
        else {
            if (y >= 1000)
                tm.Year = CalendarYrToTm(y);
            else    // (y < 100)
                tm.Year = y2kYearToTm(y);
            tm.Month = Serial.parseInt();
            tm.Day = Serial.parseInt();
            tm.Hour = Serial.parseInt();
            tm.Minute = Serial.parseInt();
            tm.Second = Serial.parseInt();
            t = makeTime(tm);
            RTC.set(t);        // use the time_t value to ensure correct weekday is set
            setTime(t);
            Serial << F("RTC set to: ");
            printDateTime(t);
            Serial << endl;
            // dump any extraneous input
            while (Serial.available() > 0) Serial.read();
    t = now();
    if (t != tLast) {
        tLast = t;
        printDateTime(t);
        if (second(t) == 0) {
            float c = RTC.temperature() / 4.;
            float f = c * 9. / 5. + 32.;
            Serial << F("  ") << c << F(" C  ") << f << F(" F");
        Serial << endl;
// print date and time to Serial
void printDateTime(time_t t)
    printDate(t);
    Serial << ' ';
    printTime(t);
// print time to Serial
void printTime(time_t t)
    printI00(hour(t), ':');
    printI00(minute(t), ':');
    printI00(second(t), ' ');
// print date to Serial
void printDate(time_t t)
    printI00(day(t), 0);
    Serial << monthShortStr(month(t)) << _DEC(year(t));
// Print an integer in "00" format (with leading zero),
// followed by a delimiter character to Serial.
// Input value assumed to be between 0 and 99.
void printI00(int val, char delim)
    if (val < 10) Serial << '0';
    Serial << _DEC(val);
    if (delim > 0) Serial << delim;
    return;
void lichtsysteem()
   int licht_waarde = analogRead(licht);// De lichtwaarde wordt ingelezen
   int M_Volt = map(licht_waarde,0, 1023, 0, 5000);// De waarde wordt aan 5000 gezet
   unsigned long currentTime_licht = now();
   if (currentTime_licht - previousTime_licht >= interval_licht) {
    Serial.println(begintimer);
    previousTime_licht = currentTime_licht;
    Serial.println(" ");
    Serial.print(M_Volt);// print millivolt
    Serial.println( "mV ");
    delay(500); // wacht 500ms
   if(licht_waarde >= 1000 /*juiste waarde*/) //als de zon schijnt dan ...
    if(begintimer == 0)
      Serial.println("Eindtimer en begintimer geset");
      begintimer = now();
      eindtimer = now();
      Serial.println("Eindtimer geset");
      eindtimer = now();
    if(begintimer > 0 && eindtimer > 0)
      aantal_uren_zonlicht = aantal_uren_zonlicht + eindtimer - begintimer;
      begintimer = 0;
      eindtimer = 0;
      begintimer = 0;
      eindtimer = 0;
////// TOT HIER IS AL JUIST
   if(flag_bijbelichting == false)
    byte som_tijd = som_waarde - hour();
    if(som_tijd <= 11 - aantal_uren_zonlicht)
      flag_bijbelichting = true;
      lichtsysteem2();
      if(hour()>22 && aantal_uren_zonlicht <= 11)
       lichtsysteem2();
void lichtsysteem2()
  if(relais_licht == HIGH)
    relais_licht = HIGH;
  if(begintimer = 0)
    begintimer = hour();
    eindtimer = hour();
    eindtimer = hour();
  if(aantal_uren_zonlicht + eindtimer - begintimer > 11)
    relais_licht = LOW;
if (begintimer = 0)
= is assignment, == is comparison
