Behaviour of Serial monitor after a lot of reading loop following shell commands
I run shell commands and retrieves results in a loop.
It works perfectly a few times then suddenly the answers are totally unreadable.
Responses on the serial console:
Here all is well (loop 1 to 60).
Mode:Managed Frequency:2.442 GHz Access Point: 00:27:22:A2:45:2A
inet addr:192.168.65.120 Bcast:192.168.65.255 Mask:255.255.255.0
59
60
inet addr:192.168.65.1 inet addr:192.168.65.1Ö
And after 60 loops, it is unreadable (number of good loops are random).
monitor send something that looks like: LMNOPQRSTUVWXYZ^_`abcdefghijklmnopqrstuvwxyz{|} (strange response plus some non-printable characters)
Is it a monitor problem, a Yun problem, or a error on my code (Most Probable).
Any ideas or suggestions are welcome.
Thanks in advance.
Charles
My code is as follows, to test it you need to connect your ‘Yun’ on access point as a client, the code will give you some information about the connection.
#include <Process.h>
#include <Bridge.h>
#include <HttpClient.h>
int compteur = 0;
Serial.begin(115200); // initialize serial communication
while(!Serial); // do nothing until the serial monitor is opened
Serial.println(“Starting bridge…\n”);
pinMode(13,OUTPUT);
digitalWrite(13, LOW);
Bridge.begin(); // make contact with the linux processor
digitalWrite(13, HIGH); // Led on pin 13 turns on when the bridge is ready
delay(2000); // wait 2 seconds
Process wifiCheck; // initialize a new process
wifiCheck.runShellCommand(“iwconfig wlan0 | grep ‘Mode’ 2>&1”); // command you want to run
while (wifiCheck.available() > 0) {
char c = wifiCheck.read();
Serial.print(c);
//wifiCheck.runShellCommand(“help”); // command you want to run
wifiCheck.runShellCommand(“ifconfig wlan0 | grep ‘inet’”); // command you want to run
Serial.print(c);
++compteur;
Serial.println(compteur);
Serial.println(">");
// while there’s any characters coming back from the
// process, print them to the serial monitor:
Thanks for the example that reliably trigger the bug, this one was really hard to track down.
It seems that under certain circumstances the python side of the bridge delays the transmission of data, so I raised a bit the timeout.
If you want to try the fix, you can change the Bridge.cpp file in your arduino installation, or wait for the next nightly build.
Tested in loop for 2 days without any problem! Thanks maglie for this quick fix on the Bridge.cpp !
I read this thread only after writing my post on a similar problem that I was facing by simply running the standard Bridge\HttpClient sample. See "Weird output from Bridge" http://forum.arduino.cc/index.php?topic=189834.0
Now I'm going to get the new Bridge.cpp file and test it to see if it solves the issue.
cmaglie: Thanks for the example that reliably trigger the bug, this one was really hard to track down.
https://github.com/arduino/Arduino/commit/ca90bf75cb1e256f728e879dc83d17bf3e02197b
I found the same issue today, with all code downloaded recently. Do I have to recompile and/or reinstall anything more than the Arduino application?
@AndersJJ you can either: - replace your copy of Bridge.cpp (located at IDE_FOLDER/libraries/Bridge/src) and replace it with this one - Download one of the nightly builds of the IDE from http://arduino.cc/en/Main/Software. These are built every day with the latest code available on github
[quote author=Federico Fissore link=topic=188955.msg1409193#msg1409193 date=1380405259] @AndersJJ you can either: - replace your copy of Bridge.cpp (located at IDE_FOLDER/libraries/Bridge/src) and replace it with this one - Download one of the nightly builds of the IDE from http://arduino.cc/en/Main/Software. These are built every day with the latest code available on github [/quote]
Tip #1 is reported by others to work, but #2 does not.
