bitte um Hilfe,
versuche seit Tagen den Temperatursensor zu benutzen.
irgendwie meckert IDE mit der library, folgende Fehlermeldung:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\fenerium\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\fenerium\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\fenerium\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10809 -build-path C:\Users\fenerium\AppData\Local\Temp\arduino_build_534597 -warnings=none -build-cache C:\Users\fenerium\AppData\Local\Temp\arduino_cache_719210 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.arduinoOTA.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -verbose C:\Users\fenerium\Documents\Arduino\sketch_may05a\sketch_may05a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\fenerium\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\fenerium\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\fenerium\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10809 -build-path C:\Users\fenerium\AppData\Local\Temp\arduino_build_534597 -warnings=none -build-cache C:\Users\fenerium\AppData\Local\Temp\arduino_cache_719210 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.arduinoOTA.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -verbose C:\Users\fenerium\Documents\Arduino\sketch_may05a\sketch_may05a.ino
Using board 'mega' from platform in folder: C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.22
Using core 'arduino' from platform in folder: C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.22
Build-Optionen wurden verändert, alles wird neu kompiliert
Detecting libraries used...
"C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.22\cores\arduino" "-IC:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.22\variants\mega" "C:\Users\fenerium\AppData\Local\Temp\arduino_build_534597\sketch\sketch_may05a.ino.cpp" -o nul
"C:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.22\cores\arduino" "-IC:\Users\fenerium\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.22\variants\mega" "-IC:\Users\fenerium\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\fenerium\AppData\Local\Temp\arduino_build_534597\sketch\sketch_may05a.ino.cpp" -o nul
In file included from C:\Users\fenerium\Documents\Arduino\sketch_may05a\sketch_may05a.ino:2:0:
C:\Users\fenerium\Documents\Arduino\libraries\DHT_sensor_library/DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
compilation terminated.
Bibliothek DHT_sensor_library in Version 1.3.4 im Ordner: C:\Users\fenerium\Documents\Arduino\libraries\DHT_sensor_library wird verwendet
exit status 1
Fehler beim Kompilieren für das Board Arduino/Genuino Mega or Mega 2560.
sketch_may05a.ino (843 Bytes)
