Below are my ADXL357 accelerometer reading when calculating vibrations of a engine. I have a feeling that the g is being calculated wrong
Hi
I am using ADXL357 accelerometer, and i am trying to record sensitivity in terms of g.
here is the algorithm for taking out raw value and calculation of g through it
int sensitivity = 19.5
float convert_to_g(raw_reading, sensitivity)
     // Convert raw readings to acceleration in g
     return (raw_reading * sensitivity) / 1000000;
// Split data
                xdata = (xdata1 >> 4) + (xdata2 << 4) + (xdata3 << 12);
                ydata = (ydata1 >> 4) + (ydata2 << 4) + (ydata3 << 12);
                zdata = (zdata1 >> 4) + (zdata2 << 4) + (zdata3 << 12);
                // Apply two complement
                if (xdata >= 0x80000)
                    xdata = ~xdata + 1 ;
                if (ydata >= 0x80000)
                    ydata = ~ydata + 1;
                if (zdata >= 0x80000)
                    zdata = ~zdata + 1;
                acc_x = convert_to_g(xdata, sensitivity_X);
                acc_y = convert_to_g(ydata, sensitivity_Y);
                acc_z = convert_to_g(zdata, sensitivity_Z);
and on using this algorithm
AccToTime_adxl357EngTopMount-X
AccToTime_adxl357EngTopMount-Y
AccToTime_adxl357EngTopMount-Z
FFT_adxl357EngTopMount-Y
FFT_adxl357EngTopMount-Z
, here is the plot of the acceleration in terms of FFT, RMS and with time. The mounting position of the sensor is Z-axis is perpendicular to g and X axis is aligned with the earth's gravity.
So i want to know that is this the right way, or am i doing something wrong?
Hello Sonofgod123
Perform some data logging and analyses to see what happens.
Should be float, not int.
What datatypes are raw_reading and sensitivity here? I'm surprised this even compiles if you don't name your datatypes.
What format is the incoming data that requires this "Apply two compliment" transformation?
The datasheet
ETA: looking at your graphs, I'm surprised that the noisy Y and Z values don't go below zero.
Please post all the code.
Hi so basically now i am coding in PYTHON on pi and got similar results.
import spidev
import time
import csv
from datetime import datetime
    # SPI setup
SPI_MAX_CLOCK_HZ = 10000000
SPI_MODE = 0b00
SPI_BUS = 0
SPI_DEVICE = 0
spi = spidev.SpiDev()
spi.open(SPI_BUS, SPI_DEVICE)
spi.max_speed_hz = SPI_MAX_CLOCK_HZ
spi.mode = SPI_MODE
    # Memory register addresses
XDATA3 = 0x08
XDATA2 = 0x09
XDATA1 = 0x0A
YDATA3 = 0x0B
YDATA2 = 0x0C
YDATA1 = 0x0D
ZDATA3 = 0x0E
ZDATA2 = 0x0F
ZDATA1 = 0x10
RANGE = 0x2C
POWER_CTL = 0x2D
REG_RESET = 0x2F
REG_DEVID_AD = 0x00
REG_DEVID_MST = 0x01
REG_PART_ID = 0x02
REG_REVID = 0x03
REG_STATUS = 0x04
    # Device values
RANGE_10G = 0x01
RANGE_20G = 0x02
RANGE_40G = 0x03
MEASURE_MODE = 0x06  # Only accelerometer
    # Operations
READ_BYTE = 0x01
WRITE_BYTE = 0x00
sensitivity_X = 19.5
sensitivity_Y = 19.5
sensitivity_Z = 19.5
def write_register(this_register, this_value):
    data_to_send = (this_register << 1) | WRITE_BYTE
    spi.xfer2([data_to_send, this_value])
def read_register(this_register):
    data_to_send = (this_register << 1) | READ_BYTE
    result = spi.xfer2([data_to_send, 0x00])
    return result[1]
def read_multiple_data(addresses, data_size, read_data):
    spi.writebytes([addresses[i] << 1 | READ_BYTE for i in range(data_size)])
    read_data[:] = spi.readbytes(data_size)
def set_Frequency_range():
    write_register(FILTER_CTL, frequency)
def set_measure_range(measure_range):
    write_register(RANGE, measure_range)
def enable_measure_mode():
    write_register(POWER_CTL, MEASURE_MODE)
def convert_to_g(raw_reading, sensitivity):
     # Convert raw readings to acceleration in g
def main():
    spi.max_speed_hz = 100000  # Set SPI speed to match the sensor requirements
    write_register(RANGE, RANGE_2G)  # 2G
    write_register(POWER_CTL, MEASURE_MODE)  # Enable measure mode
    time.sleep(1)
set_measure_range(RANGE_10G)
#set_Frequency_range()
timestamp_str = datetime.now().strftime("%Y%m%d%H%M%S")
csv_filename_X = f'adxl357X_{timestamp_str}.csv'
csv_filename_Y = f'adxl357Y_{timestamp_str}.csv'
csv_filename_Z = f'adxl357Z_{timestamp_str}.csv'
start_time = time.time()
while True:
                elapsed_microseconds = ((time.time() - start_time))  # converting time to microseconds
                range_value = read_register(RANGE)
                power_ctrl = read_register(POWER_CTL)
                analog_id = read_register(REG_DEVID_AD)
                mst_id = read_register(REG_DEVID_MST)
                part_id = read_register(REG_PART_ID)
                rev_id = read_register(REG_REVID)
                status = read_register(REG_STATUS)
                xdata1 = read_register(XDATA1)
                xdata2 = read_register(XDATA2)
                xdata3 = read_register(XDATA3)
                ydata1 = read_register(YDATA1)
                ydata2 = read_register(YDATA2)
                ydata3 = read_register(YDATA3)
                zdata1 = read_register(ZDATA1)
                zdata2 = read_register(ZDATA2)
                zdata3 = read_register(ZDATA3)
                # Split data
                # Apply two complement
                if xdata >= 0x80000:
                    xdata = ~xdata + 1
                if ydata >= 0x80000:
                    ydata = ~ydata + 1
                if zdata >= 0x80000:
                    zdata = ~zdata + 1
                #print(range_value)
                print(f"{elapsed_microseconds}, X:{acc_x:.6f}g, Y:{acc_y:.6f}g, Z: {acc_z:.6f}g")
                with open(csv_filename_X,'a') as log:
                        output = "{},{}\n".format(elapsed_microseconds,acc_x)
                        log.write(output)
                with open(csv_filename_Y,'a') as log:
                        output = "{},{}\n".format(elapsed_microseconds,acc_y)
                        log.write(output)
                with open(csv_filename_Z,'a') as log:
                        output = "{},{}\n".format(elapsed_microseconds,acc_z)
                        log.write(output)
this is the complete python script.
I have mounted the sensor on a diesel engine using magnetic mounting. I am trying to calculate the rpm using vibrations in a engine but i feel my FFT values are wrong as when i measure peak of FFT its similar for all rpm.
700RPM
1500RPM
2000RPM
Its in the form of left-biased 2's complement
actually the code was in python, i just changed it into C. I have posted the complete python script. I forgot to put their data types. both of them are integer type.
i performed data logging but i am getting same graphs for different data recorded at different rpm's of the engine
Instead of:
why not:
long xdata = (xdata1 << 4) + (xdata2 << 8) + (xdata3 << 16);
...then it's in a nice microgQ28.4 which you convert to g with xdata/16000000.0
Something definitely looks wrong with the sign handling, since your Y & Z graphs look like the readings have been abs(??) -filtered, and your X graph looks like it's centered around -19.5.
