Besoin d'aide adafruti RFID arduino
Salut les gens je travaille actuellement sur un projet de lecture de carte sans contact, j’utilise donc le shield adafruit.
mon code donne :
#include <Wire.h>
#include <Adafruit_NFCShield_I2C.h>
#define IRQ (2)
#define RESET (3)
Adafruit_NFCShield_I2C nfc(IRQ, RESET);
void setup(void) {
** Serial.begin(115200);**
** Serial.println(“Hello!”);**
** nfc.begin();**
** uint32_t versiondata = nfc.getFirmwareVersion();**
** if (! versiondata) {**
** Serial.print(“Didn’t find PN53x board”);**
** while (1);**
** Serial.print(“Found chip PN5”); Serial.println((versiondata>>24) & 0xFF, HEX);**
** Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);**
** Serial.print(’.’); Serial.println((versiondata>>8) & 0xFF, DEC);**
** nfc.SAMConfig();**
** Serial.println(“Waiting for an ISO14443A Card …”);**
void loop(void) {
** uint8_t success;**
** uint8_t uid = { 0, 0, 0, 0, 0, 0, 0 };**
** uint8_t uidLength; **
** success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);**
** if (success) {**
** Serial.println(“Found an ISO14443A card”);**
** Serial.print(" UID Length: “);Serial.print(uidLength, DEC);Serial.println(” bytes");**
** Serial.print(" UID Value: “);**
** nfc.PrintHex(uid, uidLength);**
** Serial.println(”");**
** if (uidLength == 4)**
** Serial.println(“Seems to be a Mifare Classic card (4 byte UID)”);**
** Serial.println(“Trying to authenticate block 4 with default KEYA value”);**
** uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };**
** success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);**
** if (success)**
** Serial.println(“Sector 1 (Blocks 4…7) has been authenticated”);**
** uint8_t data[16];**
** success = nfc.mifareclassic_ReadDataBlock(4, data);**
** if (success)**
** Serial.println(“Reading Block 4:”);**
** nfc.PrintHexChar(data, 16);**
** Serial.println("");**
** delay(1000);**
** else**
** Serial.println(“Ooops … unable to read the requested block. Try another key?”);**
** else**
** Serial.println(“Ooops … authentication failed: Try another key?”);**
** if (uidLength == 7)**
** Serial.println(“Seems to be a Mifare Ultralight tag (7 byte UID)”);**
** Serial.println(“Reading page 4”);**
** uint8_t data[32];**
** success = nfc.mifareultralight_ReadPage (4, data);**
** if (success)**
** nfc.PrintHexChar(data, 4);**
** delay(1000);**
** else**
** Serial.println(“Probleme”);**
j’arrive donc grasse a ce programme de lire l’id de la carte mifare mais je n’arrive pas a stocker l’id de cette carte dans une variable.
help me pls <3 :slight_smile:
Bonjour, Il faut mettre ton code entre "balises code" pour être plus lisible. ;) Tu sélectionnes ton code est tu "cliques" sur l'icone "feuille de papier avec le signe +" @+
