Best arduino, stepper motor, motor driver, ethernet shield to use
Hi I need advice on the following..
***In arduino what is the best arduino to use.. maybe ur best choice..
***In stepper motors(bi-polar and unipolar) when it comes to torque and accuracy what best motor to use or ur best choice.. Btw i prefer bipolar here..
***In the motor driver for the stepper motor what is the best to us that doesn't heat up fast.. ur best choice..
***What would be the best ethernet shield to use to put in arduino so i can have both the motor driver and ethernet shield plugged on my arduino?..
Thank you and more power.
The one that has the required number of input and output pins.
The one that has the required torque and accuracy. Since you haven't said anything about what your torque and accuracy requirements are, you can't expect us to know.
The best one to use is one that has the voltage and current capabilities, with plenty of reserve, to drive your motor(s). Since you haven't told us what those voltage and current requirements are, you can't expect us to know.
The ethernet shields are SPI devices, meaning that they use pins 11, 12, and 13 for communication, and typically use 10 for the ethernet slave select pin and 4 for the SD slave select pin.
The Wiznet based ethernet shields have more hardware supplied capabilities, offloading a lot of programming from the Arduino. As a result, they are simpler to use.
Since you intend to use shields, the answer to your first question needs to be revised to rule out any non-shield compatible variations.
By the way, there was not a programming question asked here, so this is the wrong forum.
endl3ss:
Will need torque and speed needed to be able to answer.
endl3ss:
Will know what motor would be needed before being able to suggest a driver for it.
bld:
endl3ss:
endl3ss:
Hmm I don't have the right number yet.. but i think something that can lift 15 to 20 kg.. I'll be needing a real strong stepper motor..
I've been thinking of ardumoto or the easydriver.. which do you think is better?
PaulS:
**What do you think of OSEPP™ Mega 2560 compared to the Arduino mega 2560?.. I plan on using the 2560 because of the memory and pins..
**Well something that can lift heavy objects like 15 - 20kg.. I don't have the right number yet..
**I plan on using the ardumoto or the easydriver for the stepper motor which do you think is better?
**I really don't know if im going to use shields because i need to have both the ethernet and motor driver.. Is there an arduino package or something that have the ethernet and motor driver?
