I only have a Leonardo board for testing this project but wonder which would be best to use.
It will need a wifi shield and the project is to read ir codes which I can do now. Then finally use the system to send the read and stored ir codes back to Control the equipment via an ir diode. after the read process that part can be removed and the board set up purely for the control stage of the project. However the wifi shield and ir tx diode is needed along with sufficiant connections to a ds1809 for control of a volume level cct.
Question finally is which board would be the best to go for.
Any help appreciated
Thanks
M
