Best distance sensor
Hello all,
I'm looking for the best sensor for distance to use with Arduino.
The problem is that i need to check for small delta-distance. I have a rotating table that isn't perfectly planar and it have a +- 1,5 mm distorsion.
How can i measure delta-distances of 0,1 mm?
I've tried with "Ultrasonic Module HC-SR04" but without great success.
Any help?
Thanks,
I've just tried laser emitter+photoresistor. Seems to be a good option.
Any suggestion?
0.1 mm over km?
0.1 mm in distances between 10-12 mm and slow movement (about 1 mm every 30 seconds)
Short range - Sharp may be good option.
