Those motor driver chips should be OK, but you can do it more simply by using a single transistor, connected to a digital output pin via a resistor. You’ll still need a back-EMF protection diode, too.
You will need a transistor with a current rating high enough for the motor you’re using. The back-EMF protection diode is require will all inductive loads. It’s a reverse biased diode connected in parallel with the load. If you have a search on the forum for relay driver circuits, you’ll see what I mean – just swap the relay coil for a motor!
int switchPin = 2; // switch input
int motor1Pin = 3; // H-bridge leg 1 (pin 2, 1A)
int motor2Pin = 4; // H-bridge leg 2 (pin 7, 2A)
int enablePin = 9; // H-bridge enable pin
int ledPin = 13; // LED
// set the switch as an input:
pinMode(switchPin, INPUT);
// set all the other pins you're using as outputs:
pinMode(motor1Pin, OUTPUT);
pinMode(motor2Pin, OUTPUT);
pinMode(enablePin, OUTPUT);
pinMode(ledPin, OUTPUT);
// set enablePin high so that motor can turn on:
digitalWrite(enablePin, HIGH);
// blink the LED 3 times. This should happen only once.
// if you see the LED blink three times, it means that the module
// reset itself,. probably because the motor caused a brownout
// or a short.
blink(ledPin, 3, 100);
// if the switch is high, motor will turn on one direction:
if (digitalRead(switchPin) == HIGH) {
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge low
digitalWrite(motor2Pin, HIGH); // set leg 2 of the H-bridge high
// if the switch is low, motor will turn in the other direction:
else {
digitalWrite(motor1Pin, HIGH); // set leg 1 of the H-bridge high
digitalWrite(motor2Pin, LOW); // set leg 2 of the H-bridge low
blinks an LED
void blink(int whatPin, int howManyTimes, int milliSecs) {
int i = 0;
for ( i = 0; i < howManyTimes; i++) {
digitalWrite(whatPin, HIGH);
delay(milliSecs/2);
digitalWrite(whatPin, LOW);
delay(milliSecs/2);
I would like a switch to start the motor, that way i can have it go ASAP and not have to wait till the Arduino boots up . How can i do this?
Ok so i tried to get it so when the switch is toggled it digitalWrite(enablePin, HIGH);
The when its toggled again its set to digitalWrite(enablePin, LOW); but this doesnt do anything. What am thinking wrong here…
//digitalWrite(enablePin, HIGH);
// or a short.
else {
blinks an LED
int i = 0;
delay(milliSecs/2);
delay(milliSecs/2);
// or a short.
{ // if the switch is high, motor will turn on one direction:
} // if the switch is low, motor will turn in the other direction:
else {
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge high
blinks an LED
int i = 0;
delay(milliSecs/2);
delay(milliSecs/2);
Now it works just right, the switch turns the motor on and off
Now i need help writing a working timer loop, so that after the motor is turned on it only runs for X amount of time
