Best IMU and Barometer online
Hi there!
What are the best IMU and barometer online?
For best I mean the most precise, "battery-friendly", and obviously as cheap as possible - even if I have quite a bit of budget.
I ask here because I can find the specs online but others' experiences is better!
Thank you
All of your "BESTS" are mutually exclusive. Please be a little more free with your actual requirements.
Paul
I'd like to know others' experiences to understand what IMU and BARO buy.
Precision is the main aspect to consider obviously.
I need them to vertically land a rocket from 10km of altitude in a precise target.
Fascinating!
Can you take a moment to describe the rocket flight control system, and its capabilities in terms of precision?
How will the IMU fit in?
nicolopadovandev:
One of my customers has an oxygen supply system for light aircraft. Their engineer tells me their barometer can detect a 15 ft change in altitude. I do not know what the part number is as they keep all their component stock in-house. That is probably the best you will be able to find and will require you to make the interface electronics.
Paul
jremington:
Fascinating!
I think that I'm gonna use BMP280 and MPU6050. They are very cheap and they seem to be the best ones.
jremington:
Fascinating!
Sorry for the "little" delay for me to answer.
It's going to be soldered on a PCB designed by me into the frame of the rocket itself.
I hope it to get preeetty precise bc I want it to land vertically on a precise target (like a Falcon 9 scaled).
The Flight Computer should become able to handle TVC, fins (to control the landing) and the fuel flow into the engine chamber.
