I'm building a device with an Uno that'll have an LCD display showing the length of time (mm:ss) that has elapsed, and then every 5 minutes it'll need to be reset to 00:00 and started again. The catch is that during the period it's showing the time, I also need to be reading a few sensor inputs and outputting some serial data, so I can't simply use a delay for the timer.
Should I just use Timer0 and millis to do some arithmetic, like: if(currentMillis - previousMillis > interval).... so it'll only update the display when a certain interval (1000 millis) has passed, meanwhile the main loop will keep looping and doing other stuff.
or is there a timing library that would be easier to help keep track of seconds and minutes? I'll also have a DS1307 RTC onboard, so should I just poll that every loop to get the current time and then do the math like above?
That is the simplest method, and used often.
If you want to learn interrupts, there is a nice library timer (MsTimer2) that will generate a interrupt at whatever time interval you wish. It works well. Arduino Playground - MsTimer2
