Best method of shop-style open/close as on/off switch?
Hi all, new to Arduino and looking forward to getting into it.
I'd like to use a shop's open/close sign as a trigger for Arduino fun - flipping the sign to spark off events. However, I'm struggling to know what to Google (hence why I'm here) as I can't settle on a plausibility of an approach.
What's the best type of sensor to achieve this? Essentially, I just need one side of the sign to complete a connection but it needs to a subtle design for the gimmick to be affective and also accommodate for the movement occurred after the user has flipped it.
Any help is much appreciated.
I'm not really sure what you are trying to do. Are you talking about flipping a paper/plastic sign around in a window, and that acting as the trigger? If so, you would probably want an accelerometer to do it, but if you are trying to be subtle, that may require some extensive creativity if you don't want it noticed. Hobbyist electronics are small, but they aren't tiny, and what you would need would have to be really tiny not to be noticed.
Possibly you could replace the mounting hook with a switch, but that depends on your hook.
Making paper obsolete?: The benefits of e-paper
Beside open/close, you could put today special as well.
In this particular scenario the sign is hung on a wall rather than a window so there's potential to place some kind of sensor on the wall. When I first envisaged the idea I thought simply of tin foil on one side of the sign to complete a circuit on the wall (though I imagine that would produce a lot of bounce when the sign swings as it's flipped)
What make people want to mess with your sign?
Take a look at this Arduino Playground - CapacitiveSensor
32x24 Remote Flashing LED Writing Board Menu Fluorescent Sign Message Dry Erase
Fluorescent Sign Dry Erase, Ebay, $21.49
Very cool, though I'm looking to use a physical sign as a switch. So when a real world sign reads 'open' I can trigger outputs.
For example,
  • sign has been flipped to open - digitalWrite(LED, HIGH);
  • sign has been flipped to closed - digitalWrite(LED,LOW);
That sort of thing.
Thanks everyone so far.
Ok, here we go;-
Engrave Services Laser Advertising splendid LED Light Sign Seven Colors Available
Engraving LED Light Sign, Ebay, $9.93
Maybe you could figure something out with a reed switch and a magnet? If you have control over the design of the sign then you ought to be able to arrange that there is a magnet close to the reed switch in one position and not in the other.
PeterH:
That's what I was just thinking! Maybe a magnet on the lower-left corner of sign (as an example) and a reed switch on wall so it will only line up when one side of sign is flipped. Then code will read it as "open" or "closed". Hehe....actually have the switch be "open" when sign says "OPEN" for consistency?? :slight_smile:
Or....my other thought was a color sensor? If one side is different color than the other. Or, if could put a small square of a certain color on one side?
But, magnet & reed switch is probably best/easiest. And...if mount reed switch in/behind a strip of metal...could even use the magnet to secure the sign better and keep it from accidentally flipping or moving on it's own. Just an added bonus?
Let us know!
Good luck!
Thanks PeterH and 1ChicagoDave, that's exactly the advise I was looking for :slight_smile:
I'm pretty busy at the moment so may be a while before you see it but I'll stick a post here when it's done.
