best place for library link
Hi all,
Ages ago I had my library in the Playground. BitBucket is removing old projects and I just got the last notice.
Where do folks put thier links to libraries these days?
It seems to be a mess, theres the old playground, github, and a list you cant edit in resources.
Did I miss a helpful readme in the resources section??
Somewhere, someone removed my old link.
Thanks.
The new system is Library Manager. This is a system that allows people to easily search, install, and update libraries via the Arduino IDE, Arduino CLI, or Arduino Pro IDE. All libraries in the Library Manager index are pre-installed on Arduino Web Editor.
You can learn all about adding your library to the Library Manager index here:
Please make sure your library is compliant with those requirements before submitting it for addition to the index.
More information about Library Manager here:
https://www.arduino.cc/en/guide/libraries#toc3
Thank you so much.
Looks like I have work to do.
You're welcome. I look forward to seeing your library added to the Library Manager index!
Looks like it got added.
Rtc-Pcf8563 Phillips real time clock with alarms.
There is another lib that is likely smaller on resources, but I noticed he did not comment much and did not do the alarm feature. I notice mine does use a fair amount of resources. Maybe we can improve that.
I am sure this needs more work, there has to be a bug or something lurking.
Please leave a note on Git if something bad pops up.
I have not found my surface mounted test board but I have some dip versions of this chip I can breadboard.
Thanks,
Joe
