Best programming language for beginners?
Excellent beginner course. Stanford Engineering Everywhere | CS106A - Programming Methodology
pert:
That must be why Arduino has been such a huge failure with people new to programming. Oh wait...
I think you are mixing your apples and oranges.
IMHO the Arduino has been successful in spite of its programming language, not because of it.
Nobody in his right mind would use C or C++ if he did not have to. :slight_smile:
...R
tjones9163:
Is that the name of the language?
Yes.
Beginners
All purpose
Symbolic
Instruction
Code
it claims it's for Beginners but does not claim it's the Best which is part of the OP ask :slight_smile:
J-M-L:
I never said it was. I was only answering the OP's question that I quoted.
Fair enough was just trying to make a joke
pert:
As long as you don't say ALL the people new to programming who try it because I don't see near 100% success on the forum but then I've only been here 5 years now.
By your "how many people" metric, BASIC has been an astounding success.
By what I've been saying, 20 or 30 hours with interpreter line-number BASIC can get fundamentals down that I've seen more than a few newbies with more time miss.
Take a break, sheesh.
Robin2:
Call the men with the butterfly nets for me then.
BulldogLowell:
Computer programmers like to stand behind the scary, fiery wall like the Great Wizard of Oz. Warding off folks, lest they discover what's behind all that fire and smoke.... just some dude pulling levers.
There's a priesthood with jargon and all, and boy oh boy they HATE when outsiders fix their code and beat them to contracts.
The problem with BASIC is that it has little standardization. A modern BASIC (say, Microsoft Visual Basic, or RealBasic) has most of the features that a modern programmer should like, has a compiler that produces fast code, and has a good IDE with powerful debugging features.) But those tend to lack "embedded" features. Other BASIC compilers are specifically aimed at microcontrollers, but you're likely to think that you've been handed a completely different language than those "Desktop BASICs" (you have.) Parallax Stamp PBASIC is horribly primitive and slow, for instance (but they make up for it by including "embedded programming functions" as language keywords (like "shiftout")
Pascal was indeed designed as a teaching language. But that was back in the mid-1970s, and it's been a bit neglected since the 1980s. To be useful, it needs "extensions" beyond the basic language, which are somewhat poorly standardized. I became disenchanted with Pascal when I realized how much it cheats - the language has features and syntax that a user can't duplicate (at least, not without more 'extensions.') And the extent to which it seemed to deliberately limit itself to be ONLY a "teaching language" (not that that lasted. For a long time, a lot of the Apple system and application software was written in a Pascal-like language.)
When considering a "learning language", you need to consider the teaching and learning resources available. And your "goal" - a lot of "learn XXX in 5 weeks" sort of programming instruction (including Arduino) is about learning to do some useful things as quickly as possible. That's great, but you miss out on principles. A lot of "University introductory Computer Science" classes are big on principles and theory, but essentially only prepare you to take the next class, where you'll learn more details (and eventually, how to do something more useful than a class assignment.) (and the truth is, that even after getting through a 4-year CS degree, your actual programming skill may be "meh" by industry standards, especially if you haven't forced yourself to do some major "projects" outside the scope of the usual assignments.) And University teach different languages depending on whether you're going into theory (CS) or into actual problem solving (EE, ME, Most of the sciences, etc.) (At one of the colleges my daughter looked at, they were still teaching Fortran! To Physics or ME majors, IIRC.
So... universities today seem to be teaching Java, Python, and C++ as their "intro" languages. I've take a bunch of online classes (MOOCs.) There have been some very good classes using Java and Python. The only C++ class I took was ... pretty awful. There was also the UTexas "Embedded Systems" class that used C (and taught some "embedded C constructs, but expected you to already know the basics.)
There's also the fact that "beginning" classes are NOT going to teach you everything there is to know about a language. One of the complaints about all three of those languages is that they're HUGE, with MANY FEATURES and EVEN MORE LIBRARIES. (as opposed to, say, C, which is really tiny (but still has lots of libraries.)) Some of the features seem to be obscure nods to some tiny corner of some unknown discipline, rarely used unless YOUR PROFESSOR happened to like them (or someone where you work.) The way you learn about these generally involves coming across them in published code, and going "WTF?" and then figuring them out...) Then you can either decided that they're useful, or the product of a deranged mind who shouldn't have been allowed near a compute. (There was a post recently where someone had used C++ operator overloading such that "a = b + c;" changed b and c. Shudder.)
Finally, it doesn't really matter all that much. If you learn C++, but the next class you take is "Data Structures and Algorithms using Java", you'll have a few things to catch up on, but you're not going to be completely lost. There are a lot of similarities between languages; you find pieces that you like better, pieces that you like worse, in one or another, and it may influence what you choose to use for your personal programming. But professionally, you're more likely to have that dictated by your employer, and it won't be THAT uncommon for an prospective employer to expect their language choice to be irrelevant. If you've done GPS data logging in C# for Windows Phone, the "GPS data logging for a phone" is likely to be a more important piece of the hiring decision than the "C#" part; you'd be expected to be able to do something similar in Java for Android phones without too much additional effort.
x=3.14159
print x
3.14159
i%=x
print i%
3
Sometimes it's just about playing with the blocks directly, getting to know the shapes.
Structure? There are concepts that don't even need code to demonstrate directly, instantly.
We do get people on the forum who are semi-clueless mimes when it comes to variables despite writing scores of lines of well it runs code. That's just success waiting for help to happen, right? It it wasn't waiting, it would have happened.
westfw:
I still have my 1985 Byte issue where Niklaus Wirth wrote that to get a program right you write it twice and throw the first one away. Then he wrote that Pascal is that first one, Modula is the one to keep. And who am I to argue? I've helped fix Pascal homework because logic is logic but I swear that language is more anal-retentive than COBOL. I never tried the next step into that.
GoForSmoke:
Sheesh - I was getting all psyched up for your Modula introduction :slight_smile:
...R
I dunno. Can you actually do loops and stuff "interactively"? Certainly not in some of the microcontroller BASICs.
BASIC was my first language, and I've even written BASIC for work (a long time ago) (ok: BASIC and x86 machine language!) I don't remember ever doing much with "interactive mode" (debugging perhaps?) - maybe the interpreters I used didn't have that feature? In any case, that's just a glorified calculator - part of programming is planning the whole thing ahead...
(I had to look at i%=x for quite a while before stopped thinking "modulus? BASIC doesn't do THAT!" :slight_smile: )
(Hopefully you don't have to do LET x=3.14159 )
(Heh. LISP and FORTH have fine interactive interpreters as well, but I'm not going to recommend them either. Python does pretty well as an interactive interpreter:
>>> x=3.14159
>>> print x
3.14159
>>> i = int(x)
>>> print i
3
for i in [x/6, x/4, x/3, x/2, x]:
...   print sin(i)
0.499999616987
0.707106312094
0.866024961519
0.999999999999
2.65358979335e-06
westfw:
You can do the same sort of thing with Ruby and many of the introductions to both languages use the interactive interpreter. However I have never been able to see the point of it myself.
If I want to do calculations I have a calculator.
If I want to write a program then I want to save it in a file so I can use it over and over - or amend it if I've got it wrong.
...R
BulldogLowell:
I studied Latin in school. It's great, Today I can speak it with absolutely no one.
Apples and oranges. The first commercially useful program I wrote was in BASIC and VB is probably the language I have made most money from. I did some assembler and C/C++. Then I had to do a couple of projects in Delphi and it brought clarity, to what I had been hacking away at for years. Type, scope and OOP particularly, made so much more sense. When I went back to C++ it was so much easier to write clear, bug free code, first time around. When I switch to another language or dialect, the important lessons are carried from Pascal and just have to learn some new keyword and fit within the syntax of the constructs provided.
Robin2:
Tosh!
Sounds like the 1950s classroom where Python belongs. Where kids were punished for writing with their left hand, just because. Indentation has no computational value. It should not cause a compiler to choke. Indentation is for humans and should remain in the human domain. If it is that important, have the editor impose it automatically. While you are still trying to learn what a variable is, worrying about whitespace is a distraction nobody needs. Clearly this is a personal opinion :wink:
Once you learn how to use BASIC you'll never use it again.
Nonsense!!!
I have a Toshiba T1200 laptop with an LCD screen from about 1988 that runs QBASIC in DOS 3.3.
I still use it to collect data for my weather station. A 720K floppy disk holds months of data, and the laptop runs for hours on 6xAA batteries if the power goes out!
Also keeps a nice plot of the last ~20 hours of average wind speed and gusts on the screen.
For the BASIC aficionados among you, here is the wind gauge code:
REM read wind gauge and store statistics on disk.
REM circular buffer push and pull
DECLARE SUB gbuf (array!(), v!, nsp%, nsmax%)
DECLARE SUB pbuf (array!(), v!, ns%, nsp%, nsmax%)
REM plot wind speed data in box 1-600 on x, 0-99 on y, lower screen
DIM t0(600), t1(600)
DEFINT I-N
DEFSNG K
nsec = 300 'sample save interval in seconds
SCREEN 2 '640x200
' VIEW defines graphics viewport in absolute screen coords, subsequent
' pixel coords are relative to view window
' VIEW SCREEN  (ditto) but subsequent pixel coords are absolute
' Order of coordinate pairs is immaterial!
VIEW (21, 98)-(620, 198), , 1: REM view won't frame extreme edges
WINDOW (1, 0)-(600, 99): REM logical coords 1-600 on x, 0-99 on y
CLS
OPEN "com1:4800,n,8,1,cs0,ds0,cd0" FOR INPUT AS #1
LOCATE 1, 1: PRINT "Starting wind monitor at: "; DATE$; " "; TIME$
LOCATE 2, 1
INPUT "Output file name: ", n$
OPEN n$ FOR OUTPUT AS #2
PRINT #2, DATE$; " "; TIME$; " sample:"; nsec
r% = 0
REM number of points in graph, buffer pointers
n0m = 300: n0 = 0: n0p = 1
n1m = 300: n1 = 0: n1p = 1
REM get version #
'ON ERROR GOTO handler
LINE INPUT #1, a$
LOCATE 3, 1: PRINT "Version and time: "; a$
LOCATE 4, 1: PRINT "Hit Esc to exit..."
nsamp = 0: wmaxt0 = 0: avgt0 = 0: vart0 = 0
ON TIMER(nsec) GOSUB 5000
TIMER ON
10 LINE INPUT #1, a$: LOCATE 9, 33: PRINT a$; "     "
	nc = INSTR(a$, ","): a$ = MID$(a$, nc + 1)
15      temp0 = VAL(a$) / 22.6
	nc = INSTR(a$, ",")
20      temp1 = VAL(MID$(a$, nc + 1)) / 22.6: REM max reported by sensor
	IF (wmaxt0 < temp1) THEN wmaxt0 = temp1
	avgt0 = avgt0 + temp0
	vart0 = vart0 + temp0 * temp0
	nsamp = nsamp + 1
	LOCATE 11, 26
PRINT USING "& Avg: ### Max: ### mph"; LEFT$(TIME$, 5); temp0; temp1;
	IF INKEY$ <> CHR$(27) THEN GOTO 10
REM escape key hit, all done
GOSUB 5000
CLOSE #2
STOP
5000 r% = r% + 1: REM write record: average, max and s.d. this interval
avgt0 = avgt0 / nsamp
vart0 = vart0 / nsamp - avgt0 * avgt0
vart0 = SQR(ABS(vart0))
PRINT #2, USING "###.#,###.#,###.#"; avgt0; wmaxt0; vart0
CALL pbuf(t0(), avgt0, n0, n0p, n0m)
CALL pbuf(t1(), wmaxt0, n1, n1p, n1m)
nsamp = 0: avgt0 = 0: wmaxt0 = 0: vart0 = 0
REM plot data
CLS 1
' dotted gridlines
FOR i = 1 TO 600 STEP 4
PSET (i, 30): LOCATE 21, 4: PRINT "10";
PSET (i, 60): LOCATE 17, 4: PRINT "20";
PSET (i, 90): LOCATE 13, 4: PRINT "30";
NEXT i
' pull out most recent temp0 and max measurements
nsp = n0p
FOR i = n0 TO 1 STEP -1
CALL gbuf(t0(), v, nsp, n0m)
v = 3 * v: i2 = 2 * i
PSET (i2, v): PSET (i2, v + 1): PSET (i2, v - 1): PSET (i2 + 1, v): PSET (i2 - 1, v)
NEXT i
RETURN
handler:
LOCATE 3, 30
PRINT "error "; ERR; " at line "; ERL; TIME$; " "; DATE$;
LOCATE 4, 30
PRINT a$
RESUME NEXT
DEFINT K
DEFINT I-N
REM NO check for buffer underflow
v = array(nsp)
nsp = nsp - 1
IF nsp < 1 THEN nsp = nsmax
END SUB
DEFINT I-N
REM returns ns%, number of values pushed
array(nsp) = v
nsp = nsp + 1: ns = ns + 1
IF nsp > nsmax THEN nsp = 1
IF ns > nsmax THEN ns = nsmax
END SUB
MattS-UK:
That may be true of the visual part of it. But I can't see any technical difference between starting a block of code with a TAB character or starting it with a '{' character. And it saves me having to type the closing '}' And as a side effect it makes the code easy to read
Get over it :slight_smile:
...R
have the editor impose [indentation] automatically.
And of course, Python editors DO that.
I was a little surprised at how little the "whitespace issue" bothered me when using python. I mean, it's only INDENTATION that matters; other whitespace is still malleable.
(Hmm. Look at it this way: it's not the first time when a "recommended practice" has become a "required behavior of the language." The other main one I can think of is pre-declaring your variables (C, Pascal, PL/1...) (something that Python got rid of...))
westfw:
>>> x=3.14159
>> print x
3.14159
i = int(x)
print i
3
...  print sin(i)
0.499999616987
0.707106312094
0.866024961519
0.999999999999
2.65358979335e-06
My first Basic let me use bits in integer vars. I consider learning bits early to be important foundation knowledge.
Is Python deficient in that department?
I think the real beauty of Basic for Beginners is that they can get utterly sick of it before too long and move on to better. If you start on a hilltop that's going to be harder to do.
