Best protocol/way to simply connect 2-3 Arduinos to main Arduino
@MikkelD Welcome to the forum.
SPI is actually simple; it just needs a few wires more than I2C and UART for a single connection. For that you get
  • one data wire for each direction (Master -> Slave, Slave -> Master)
  • a clock signal that tells the slave when the data is valid and when the data line gets updated
  • one chip select signal for each slave
This makes SPI faster and more robust than I2C and UART.
In your case you would need 7 lines and could use just one SPI peripheral.
If you have 4 hardware UARTs on your Mega that can work as well.
