I need to find radio transmitter and receiver pair (or just transceiver) for distance up to 50m that fits:
as cheap and as small as possible
not to interfere with my main 433MHz module, so it SHOULDN'T be 433MHz. It may be 868MHz or any frequency up to 2.4GHz
as simple as possible, with few pins
What I need is to transmit 8 digits from each of my light sensor to my main Arduino module. I've found such a module but it seems complex.
Please tell me, which pins I can omit in this module? Or maybe you know specific module which is better? Best for me is 3 pins (VCC, GND, SIGNAL) like I've used in 433MHz, but I can't use 433MHz here
Yes, of course. Maximum distance between modules is 50meters. it is 2-3 meters above ground. Only obstacles are few (1-2) trees. Apart from trees, yes, there are no obstacles, good line of sight
What are you using for the current 433 MHz module and what's going on with that link (e.g. bi-directional vs uni-directional & packet size and rate & sensor/processor on the other end)?
Would it be possible to a multi-node network all on the 433 MHz which is zero extra cost to the existing node?
The direction is from sensors to LoRa node only, and then from LoRa node to my main receiver (ME). No bi-directional.
For 433MHz part I already use CC1101 transceiver
Yes, that's the module I mentioned in the original post. But there are 7pins used. Do I need all of them? I would prefer 3 pins, please see links in my original post. I will make lots of these modules, so I need simple solution
No way for wires unfortunately. I'm just installing light sensors near the woods. That's the context. Height is 2-3 meters above ground. There's no additional obstacles
@srnet I'm installing a bunch of sensors near my own apartments, but if I succeed, yes it will be a commercial product too. Please share these specific RF device names. I found only 433MHz ones so far
