Best soldering tip FYI
Wish someone would make an "anti-shake" iron, like those gyro stabilized binoculars. >:(
Wish someone would make an “anti-shake” iron, like those gyro stabilized binoculars. >:(
I know what you mean.
I rest the heel of my hand on the desk top, this keeps things from moving to a minimum.
LarryD: BTW Using distilled water on the solder iron sponge keeps the salts in the water from building up on/in the soldering iron stand.
I think you just solved a problem I didn't really know I had. I always wondered why I'd clean my tip and immediately have junk on it again.
outsider: Wish someone would make an "anti-shake" iron, like those gyro stabilized binoculars. >:(
I am suffering too, soldering and keeping still. Its impossible for me to do surface mount prototyping.
Last night I had an idea to make a pair of robotic hands, that I would use operating a pair of jog dials, with a footswitch to dip-down the soldering iron. The time it would take me to make that would distract from the rest of my projects.
I'm always looking for better tools, jigs to help.
@DocStein99
If you are considering SMD devices, a hot air rework station may be your answer.
These might be of interest:
Prop-Forge: I think you just solved a problem I didn't really know I had. I always wondered why I'd clean my tip and immediately have junk on it again.
I gave the brass mesh sponge in a tin a try after the damp sponge method. Brass mesh sponge is indescribably better.
LarryD: @DocStein99 If you are considering SMD devices, a hot air rework station may be your answer.
I just get the mother in law to breath on it :)
Yes that would work :)
You can get solder to quickly solidify by submitting it to the cold shoulder from the wife.
I am NOT considering SMD. All of those tools will not help me hold, place those tiny components. I already have a tough enough time reading labels on DIP sized chips.
That's where I was, so I got a stereo microscope. I wont be without one now.
http://www.amscope.com/3-5x-90x-simul-focal-stereo-lockable-zoom-microscope-on-dual-arm-boom-stand.html
|500x500
http://www.amscope.com/144-led-lighting-direction-adjustable-microscope-ring-light-with-adapter.html
|500x500
@DocStein99 Hot Air soldering: https://www.youtube.com/watch?v=iWjJ-lsUQ30
DocStein99: I am NOT considering SMD. All of those tools will not help me hold, place those tiny components. I already have a tough enough time reading labels on DIP sized chips.
I find a cheap USB microscope useful for this. Placing smd components i find increasingly difficult (shakes).
I wonder how the upcoming generation and new students handle this with fewer components being available in thriough hole packages.
Here is a good idea to get one stable hand :wink:
https://www.youtube.com/watch?v=_iOKOnbmJXA
Edit:
In the version I made, I added a third, middle alligator clip at the center of the rod therefore there are 3 of them.
i use something like this.
https://www.machinemart.co.uk/p/clarke-3-inch-vice-cdv30c/?da=1&TC=GS-040314019&gclid=COWAhveMgdACFdTNGwodrDEEsg
That has parallel jaws though, mine has a 2mm lip for sheet metal which is ideal for solderig PCBs.
Very solid so only twitch is the soldering iron.
Better pic, but mine is better. 2 quid from a boot sale
https://www.wonkeedonkeetools.co.uk/media/wysiwyg/27V-Vices-Meg/27V69/V-69-2_TBI_Drill_press_vice_.jpg
Those are good, got one in the shop too.
A good panavise is also a nice thing to have.
https://www.google.ca/search?q=panavise&rlz=1C9BKJA_enCA713CA713&hl=en-US&prmd=isvn&tbm=isch&tbo=u&source=univ&fir=DlHmuUzVTivrFM%253A%252C7GKe0iTB2S-OXM%252C_%253BZ9yyQh5mtQp_8M%253A%252C6pGGiMzKpwEG0M%252C_%253B_P_ns-eA084uAM%253A%252CIocbmGRqPFtgLM%252C_%253BTALzZwTBt54NOM%253A%252Cxr7lY8-Nlld7BM%252C_%253BbrnmygzzUBLVkM%253A%252C5vInuSy8npVyYM%252C_%253BZt69FgDMsLxquM%253A%252CHZyUMrk8k6GiMM%252C_%253BZ1EZo9iUdZrS_M%253A%252CiA4wgppLkFGzlM%252C_%253Bp_JzQ8P-D9UZmM%253A%252C6pGGiMzKpwEG0M%252C_%253Bekw2y67qnBp_dM%253A%252CuYQC-sa58sGOBM%252C_%253BEZJNm8d0dYvv9M%253A%252CjCReC05vKai06M%252C_&usg=__8-sRjp7zosv5gcvrXNczRsDeBYc%3D&sa=X&ved=0ahUKEwjRusLTjoHQAhVN7mMKHRM3BGUQsAQIYg&biw=1024&bih=748
I use a rotisserie jig to hold circuit boards, is nice. Has a spring to move in and out to hold the board, flips around, and holds position. I would show a picture of it here, except the forum won't allow me to insert pictures (with ease). I bought it at a flea market for like $5.00 and had no idea what it was until I looked it up when I got home. It's old and indestructible. They are rare, I've never seen one for sale on any modern electric tool supply.
I have the panavise at work, with this pcb holder :
and is indeed useful for pcb repair/rework. For assembly I have this one from Weller :
nice to own, but I have not used it so much. Both are not so cheap, but not very expensive.
Ciao, Ale.
I have seen these around but have not used them: omni vice.
|500x375
Yes, mine looks like the "panavise" on Larryd's post at the top. I havent seen any of the other tools, they are interesting.
LarryD:
I have been using this tip shape for the last 10 months.
It is great for getting around and under things you are soldering.
As the tip is bent, you can easily move the contact point on the target to achieve more/less heat transfer.
The version I have is series 936 but it works well on my Hakko F888D iron.
I Run the tip at ~410C.
Highly recommend using this.
(probably invented by someone who dropped the iron on the floor.)
How to use:
https://www.hakko.com/english/tip_selection/type_j.html
Yes nice idea thanks, for when you cant quite get the right angle with a normal straight tip. I could see this working nicely when you have to solder something that is on a board that is right next to another board so you cant get the iron tip in there right unless you remove one of the boards, but a bent tip would help so you dont have to take out a board.
