hello all
I am confused with all the ways by which i can get the servo motor which can rotate till 360 degree and i can control it to any desired angle .what is the best quick way ( i am not bothered about cost much ) to get that .
- 360 parallax feedback servo ?
- custom dc motor/other motor with encoder in feedback ? ( how to get that work and what motor and encoder will good to use ...is it easy to make custom ? )
- modifying 180 to 360 using gearbox?
- modifying 180 servo in any other way ??
Does it have to be a servo or could you use a stepper motor ?
Simplest and most reliable solution is a ready-made 360° servo.
Other solutions depend on your mechanical and elecric skills. Every servo has a gearbox so it's not always a good idea to add another gearbox.
What do you want to control with that servo?
UKHeliBob:
I can use any motor as long as i can control the angle precisely
A sail winch servo can rotate through about 3 revolutions with position control.
If a servo is suitable it will be a lot less trouble than a stepper motor. Stepper motors don't know their own position so you need a limit switch to identify the ZERO position and the program must move the motor to that position at startup so it always counts steps from the same place.
...R
DrDiettrich:
Nobody is shipping the parallax feedback and sail winch motor to india unfortunately
can you suggest any website which delivers at good cost ?
What are options available for this?
DrDiettrich:
I am controlling a knob like volume or radio
Robin2:
...R
