Best Target For VL53l0x sensor
My project is based on Target Tracking. I am using VL53l0X for tracking the traget, But my VL53l0X is not detecting the the target after 500mm. My target is a white PVC pipe of diameter 1.5 inches.
Before that i was using SHARP IR sensor but it has some reflection problems and variation in readings so i decided for this VL53L0X but unfortunately this is more disappointing. I don’t know why. Kindly tell me weather the problem is with the Target or Sensor.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
A picture of you project would help also.
We have no idea how you scan for the object.
Please supply a link to data/specs on your sensor.
What model Arduino are you using?
I know the data sheet says up to 2m range but in practice most people get a range of 150mm, at 500mm you are doing very well.
I suspect it is the curved nature of your target that is giving you this limit.
Here is the picture of project and the VL53L0x i am using.
If you have any suggestions about the shape and dimension of the target kindly share.
Ops pics.
Tom... :slight_smile:
Grumpy_Mike:
I agree when you look at the picture, the pipe is a convex surface so only a very small area will be reflecting directly back to the sensor.
So any suggestions regarding this scenario because i the area is 90 degree. And the target will move in a straight line if i use a flat surface then the beam will be not be reflected to the sensor because of variation in incident angle at every point of the target trajectory.
Maybe some 3M-Scotchlite-Reflective-Tape would work.
dougp:
Yes, good suggestion to increase the limited amount of reflected light going directly back to the sensor.
