best way to battery power mega.
what do you guys recommend to power the mega with? I've seen write ups stating the Vin port but this needs 7-12v? which means li-poly battery packs would be no good.
looking for small physical size.
on31ll:
You must have a good reason to use a big power-hungry Mega.
Try a smartphone powerbank, connected to the USB socket.
You might still have to add a dynamic load if it switches off (mine doesn’t).
Leo…
I've never used a Mega, but in theory you could have a single lipo with charger followed by a 5V boost converter, and apply that output to the 5V pin.
ShermanP:
...you could have a single lipo with charger followed by a 5V boost converter, and apply that output to the 5V pin.
So a powerbank.
The advantage of a powerbank is that charger and battery protection are buildin.
And 5volt enters the Mega via a fused USB socket.
Leo..
Wawa:
i am very very new to arduino and coding. i bought the mega and the uno. when a friend helped write the code the uno ran out of space and i am in no way goo enough yet to edit that code to cut out the rubbish thats not "needed"
I'd rather try to optimize a code to make it fit to Uno
alesam:
i think that too as there is code included for an ethernet shield and SD card but that is no longer being utilised/connected
the removing or optimising the code is above my skill level I'm very new to this.
