Best way to forward an HTTP GET request to HTTPS server
I want to send a HTTP GET request to a server using Arduino. The api I am using is HTTPS based. I want to know if and how is it possible to send a request to HTTPS when Arduino supoorts only HTTP.
You would need to relay the request through another server. Google "relay server".
edit: I haven't tried this, but the least expensive way would be using a RPi as the relay.
It is NOT possible for the Arduino to make an HTTPS request.
It is possible for the Arduino to make a GET request, in HTTP format, to a different server or script that then makes the HTTPS request supplying the needed credentials.
@PaulS can you provide me with a server which would be able to forward such requests?
komalhm:
Yes, for $100 per month.
OK
or; you could implement TLS over HTTP..
http://ardiri.com/blog/utls_defining_lightweight_security_for_iot_part_1
http://ardiri.com/blog/utls_defining_lightweight_security_for_iot_part_2
http://ardiri.com/blog/utls_defining_lightweight_security_for_iot_part_3
http://ardiri.com/blog/utls_defining_lightweight_security_for_iot_part_4
http://ardiri.com/blog/utls_defining_lightweight_security_for_iot_part_5
as of today; working RC4 and AES128/192/256 ciphers - i have some RSA(1024 bit) code on Arduino for key exchange, however, pre-shared keys can also work (i have a demo of this right now). i got into creating microTLS because there needs tobe something for low powered micro-controllers.
ardiri:
Aaron Ardiri - IoT Blog: µTLS - defining lightweight security for IoT (part 2)
Aaron Ardiri - IoT Blog: µTLS - defining lightweight security for IoT (part 3)
Aaron Ardiri - IoT Blog: µTLS - defining lightweight security for IoT (part 4)
Aaron Ardiri - IoT Blog: µTLS - defining lightweight security for IoT (part 5)
Hello Ardiri, congratulations on your work! I'm planning to use Arduino to restart some devices, but the connection between the Arduino and the server goes through an open wifi network, I would like to know if there is something ready and concrete that adds a basic encryption to the communication, something that can prevent someone as any program can see the command to restart the device.
Thank you
I recommend Speck. It's designed for resource limited processors like the AVR.
aarg:
Thanks for your answer!
I already did a Google search on arduino "Speck" and saw that the practical examples are few and my level of knowledge is small, but I will continue the research.
camalau:
