best way to get two way communication between boards ?
I know the questions is a bit vague but I need to know a good easy way to get two way wireless Communication between two ardunio boards of ranged under 15 meters.
so far i have only found guides on between the board and a computer.
Use Xbee radios. Not the cheapest but certainly the simplest to install and operate.
Sorry I thought the xbees where only 1 way ?
You are wrong, they are two way.
Sorry just to be 100% clear this is the module you are talking about
http://www.ebay.com.au/itm/Xbee-V03-Shield-Board-Arduino-HC-06-Wireless-Bluetooth-Bee-V2-0-Slave-Module-/191736192833?hash=item2ca45e1f41:g:KFoAAOSwpzdWqytl
otherwise thank you very much il buy a few and start prototyping
The nRF24L01+ modules are only about £2 each and work very well.
I got my nRF24s working with this Tutorial
I suggest you use the TMRh20 version of the RF24 library - it solves some problems from the ManiacBug version
The pair of programs in this link may be useful.
...R
That is a bluetooth-2 board and not really suitable as the range is about 10m. A bluetooth-4 module is good for about 60m.
No.
This. https://www.arduino.cc/en/Main/ArduinoXbeeShield
Here is a compiled wishlist of the things you’d need for xbees, and here is a great 5 part tutorial on using Xbees.
Note: If you want to communicate two arduino’s directly, you’d need two shields, and two header kits.
