So I made a joystick with an Arduino Due. And it works pretty well on USB. However, I also wanted to expand this to support SNES and Genesis, and I've run into some problems here.
The main issue is that Genesis and SNES are both 5V machines, while the Due is 3.3. I bought some line level converters from Adafruit, but I'm having some weird issues with the 8 channel one I wanted to use for the Genesis. It seems to be only putting out about 2 V on the high (VCCB) side instead of the desired voltage, although it does respond per the logic on the low side. Although I'm not the world's greatest solderer, I'm pretty sure that the pins on the reverse are all making contact with the board, and there are no shorts. So I'm not sure if the Genesis (and/or Ardunio's 5V pin when using USB cable) just aren't supplying enough voltage for what I want to do, or if I damaged the board somehow.
Here's a photo of this part of the setup for reference:
Note that the pic is slightly old, as I wasn't connecting the output enable pin. I've fixed that problem after I took the picture.
Here's the full album for reference:
https://plus.google.com/u/0/photos/114287335677693389173/albums/6136902247702077873
So now I'm not sure how to proceed. I've more or less written off the chip, unless someone has any suggestions. however, I also realize that the 3 button Genesis controller is a super controller, so I can implement that with just a MUX and some pull up resistors if I want to forego 6 button support.
However, with that solution, I would also be exposing the Arduino due's pins to 5V directly. Granted, I would not be powering the Arduino on at all when connected to a Genesis, but would this still cause damage to the board? Is there a recommended way I could protect the board without adding too much complexity? I'm running a bit short of room in my case.
The second option is to replace the Arduino Due with a Leonardo. I THINK I have the exact number of IO I need on a Leondardo (4 directions, 8 buttons, 7 Genesis data lines and the SNES latch signal), but it leaves me no margin. My plan for the SNES would be to use the SPI lines; if that isn't viable and I need to bit-bang it, I would need two more data lines. I'm also not sure about the USB device profile for the Leonardo. Since the Due has a dedicated programming port, I was able to completely disable the serial profile from the USB native port. Since this wouldn't really be an option with the one-port Leonardo, I'm not sure if Windows would still let me use the HID portion of the device without specifying a driver for the serial port part.
Any thoughts or other suggestions?
