Best Way to Save Power
  1. Analog conversion is switched off to save power
  2. You should not have deleted the comments while copying the code. If you do not understand the comments you should read the watchdog timer section in the datasheet. http://www.atmel.com/dyn/resources/prod_documents/doc2545.pdf Section 10.8
Udo
