best way to set pin high/low without using digitalWrite?
If I want to set pin 16 high on a Nano I’ve tried these three methods and they all work.
digitalWrite (16, HIGH);
PORTC = 1 << 2;
PORTC = 0B00000100;
In setup I have three of the pins in PORTC set as outputs. I see no use in using DDRC… because setting the pinMode only happens once during setup so it doesn’t make the code any faster.
pinMode(14, OUTPUT); //14 is pin A0 on UNO and Nano
pinMode(15, OUTPUT); //15 is pin A1
pinMode(16, OUTPUT); //16 is pin A2
But I’m not using any of the other pins in PORTC YET.
Question…
If I later want to use the other three available pins in this port (17,18,19) for other things, will doing something like PORTC = 0B00000100; mess with those other three pins, because obviously I’m setting them to 0?
Does using PORTC = 1 << 2; instead fix this problem and leave the other pins alone?
How about something like PORTC = PORTC | 0B00000100; ?
Is this preferable to using PORTC = 1 << 2; ?
If you do:
PORTC = 1 << 2;
you’ll affect all bits. Use AND, OR and XOR operations to manipulate bits:
PORTC |= 1 << 2; //set bit 2
PORTC &= ~(1 << 2);  //clear bit 2
PORTC ^= 1 << 2;  //toggle bit 2
OK. I didn’t think of it that way.
So is doing this…
just as good as doing
PORTC |= 1 << 2;
I prefer doing it the longer way because I can easily visualise the entire byte and which ones are 1 or 0.
ALSO
Wouldn’t using | and then << mean that it’s using more clock cycles than the other method that only uses a single | ?
dentaku:
So is doing this…
PORTC |= 1 << 2;
The two statements are equivalent logically. A good compiler should generate basically the same code.
ALSO
[/quote]
The compiler should compute a constant shifted by ‘n’ bits prior to encoding (if you have a variable shifted by ‘n’ that’s different.) So “1<<2” should be the same at code generation as “0b00000100”.
It should just cost the cycles for a read/modify/write either way.
What is "best"? Fastest? Easiest to understand when you read the code? Most impressive to the opposite sex?
Blackfin:
ALSO
Aha. That makes sense that the compiler can do this because it’s not a variable.
Hmmm. It might be interesting to do an experiment using avr-objdump and see what the compiler does using different methods for setting a bit high.
Not that I really understand that kind of code though :slight_smile:
dentaku:
Dead horse beating. But, here you go…
 1aa:	42 9a       	sbi	0x08, 2	; 8
 1ac:	42 98       	cbi	0x08, 2	; 8
 1ae:	98 b1       	in	r25, 0x08	; 8
 1b0:	84 e0       	ldi	r24, 0x04	; 4
 1b2:	89 27       	eor	r24, r25
 1b4:	88 b9       	out	0x08, r24	; 8
Writing a bit to a PIN register toggles the output on some AVR processors…
 1b0:	94 e0       	ldi	r25, 0x04	; 4
PINC = 1 << 2;  //toggle bit 2
 1b6:	96 b9       	out	0x06, r25	; 6
The single instruction optimization relies on the port being in the lower 32. In other words some ports on some processors will require more code.
