I guess that depends on which battery holder you choose. Also remember that most applications that use a CR2032 expect the battery to last a long time and therefore fewer insertion/removal cycles.
The ones that are simply bare metal "clips" require the PCB to provide the other battery contact which could over time start to wear the copper away.
I would stick with one of those horizontal plastic/metal ones with a simple retaining clip as used in a lot of PC motherboards.
To be honest, they look like cheap crap. They appear to rely on the plastic catch on the lid to keep them closed so the coin cell keeps touching the battery contacts. If the plastic catch breaks/fails, then the coin cell escapes into the innards of your project - where you will have a nice piece of conductive metal coming into contact with all sorts of things it shouldn't!
