Best way to use two structs for a config file
Hello,
I need to complete a configuration file for my stations.
My stations have serveral sensors and I use my cofniguration file to activate it or not, or to define the analog pin, where there are connected.
Here is an exemple of my struct for a station pay attention to bud1_active, bud2_active, bud3_active and bud4_active)
struct ini_station
  const char* nom;
  const int station_id;
  const int analogRResolution;
  bool actif; //Activate station: true/false
  const int32_t tx_interval; // // (sec) 15, 30, 60 (1mn), 120 (2mn), 300 (5mn), 900 (15mn), 1800 (30mn), 3600sec (1h)
  const bool mprint;          // Display print in the terminal
  const int sd;             //Activate SD card: 0=inactive; 1=active; 2=active and read config from SD
  //boolean conf_from_sd = false;   // If sd is active and conf_from_sd, the sensor configuration from SD will considered instead of the conf from that ino file
  bool logger;         // (sd must be true) If true, the station activity will be saved into the SD card
  const bool oled;                // Activate the OLED display
  const bool rtc;                 // Activate the RTC DS3231 clock
  const bool rtc_calibrate;       // Calibrating the RTC DS3231 clock. RTC. RTC must be true (Default false)
  const bool eeprom;              // Activate the EEPROM chip. It must be true to save the LoRaWAN keys
  const bool watchdog;
  const bool sleepMode;
  const int lora;                 // 0=unactivate LoRaWAN; 1=OTAA; 2=ABP
  const bool temperature_active;  // te; a;
  const bool pressure_active;     // pr; b;
  const bool humidity_active;     // hu; c
  const bool luminosity_active;   // lu; d;
  const byte wm1_active;          // w1; e;
  const byte wm2_active;          // w2; f;
  const byte wm3_active;          // w3; g;
  // bool datetime_active;        // da; h;  // date_time_active is always the same than rtc
  const bool temperature_soil_active; // ts; i;  // Must define the analog pin
  const byte gauge_active;           // ga; j;
  const bool battery_active;      // ba; k;
  const byte wattering_active;    // ar; l;
  const byte aneno_active;        // an; m;
  const bool irtemp_active;       // ir; n;
  const bool wrm_active;          // wr; o
  const byte bud1_active;         // b1; p;
  const byte bud2_active;         // b2; q;
  const byte bud3_active;         // b3; r;
  const byte bud4_active;         // b4; s;
  const byte sun_active;          // su; t;
  const byte wdirection_active;   // wd; u;
  const byte wdirection_offset;
  const byte sf110bud_active;     // sb; v;
  const byte sf110leaf_active;    // sl; w;
  const char * nomDuCapteur;
  const uint8_t codeDuCapteur;
ini_station station = {
    "A12",   // Station name
    25,             // station ID
    12,             // analogReadResolution
    true,           // station active (true or false)
    15,            // TX INTERVAL (sec) 15, 30, 60 (1mn), 120 (2mn), 300 (5mn), 900 (15mn), 1800 (30mn), 3600sec (1h)
    true,           // mprint
    0,              // SD card: 0=inactive; 1=active; 2=active and read config from SD
    false,          // LOGGER: (SD must not be 0) If true, the station activity will be saved into the SD card
    false,          // OLED: Active or not
    false,          // RTC DS3231 I2C
    false,          // RTC CALIBRATE RTC Must be true. Do not forget to have it back to fase after calibrating
    false,           // EEMPROM: Active or not
    false,          // Watchdog
    false,          // SLEEP: Active the sleep mode (Arduinolowpower)
    1,              // LoRaWAN: 0=unactivate; 1=OTAA; 2=ABP;
    false,          // te; a;
    false,          // pr; b;
    false,          // hu; c
    false,          // lu; d;
    0,              // w1; e;     // 0=Unactive; 14=A0; *15=A1*; 16=A2; 17=A3; 18=A4; 19=A5
    0,              // w2; f;     // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
    0,              // w3; g;     // 0=Unactive; 14=A0; 15=A1; 16=A2; *17=A3*; 18=A4; 19=A5
    //true,         // da; h;     // date_time_active is always the same than rtc
    false,          // ts; i;     // Must define the analog pin
    0,              // ga; j;     // 0=Unactive; 14=A0; 15=A1; 16=A2; *17=A3*; 18=A4; 19=A5
    true,          // ba; k;
    0,              // ar; l;     // WATTERING // 0=Unactive; 14=A0; 15=A1; 16=A2; 17=A3; *18=A4*; 19=A5
    0,              // an; m;     // WWIND SPEED // 0=Unactive; *14=A0*; 15=A1; 16=A2; 17=A3; 18=A4; 19=A5
    false,           // ir; n;
    false,          // wr; o
    14,             // b1; p;     // 0=Unactive; *14=A0*; 15=A1; 16=A2; 17=A3; 18=A4; 19=A5
    0,             // b2; q;     // 0=Unactive; 14=A0; *15=A1*; 16=A2; 17=A3; 18=A4; 19=A5
    0,             // b3; r;     // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
    19,             // b4; s;     // 0=Unactive; 14=A0; 15=A1; 16=A2; *17=A3*; 18=A4; 19=A5
    0,              // su; t;     // SUN: // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
    0,              // wd; u;     // WIND DIRECTION 0=Unactive; 14=A0; *15=A1*; 16=A2; 17=A3; 18=A4; 19=A5 and the WindDirectionOffset
    0,              // Offset of the wind direction bar from the Noth (Degree). 0 if the bar point to the North
    0,              // sb; v;     // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
    0,              // sl; w;     // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
I have 4 bs18b20 sensors (bud1_active, bud2_active, bud3_active, bud4_active), connected to A1,A2,A3 and A4.
Thoses sensors need to be calibrated but taking a measure in a ice and hot water and I want to perfect the bellow part to be included (or merged) in the above struct
struct t_calibrate{
  const byte pin;
  float tMin; // Mesure in the ice (°C)
  float tMax;// Measure in the hot water (°C)
struct t_bs18b20 {
  const char* nom;
  float refMin; // Reference, temperature of the Ice (°C)
  float refMax; // refrence, temerature of the hot water (°C)
  t_clibrate calibrate[4]; // 4 is the number of ds18b20
// Exemple of serval station with 4 ds18b20 sensors
t_bs18b20 bs18b20[] = {
  {"Error, No station", 0, 0, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}},
  {"station 1", 0, 97, {{19, -0.8, 96.9}, {0, 0, 0}, {0, 0, 0}, {14, -1.1, 94.5}}},
  [... other station ...]
As I may have written, I want to have one configuration file for one station. So this should be enough for one station (station 1)
t_bs18b20 bs18b20 = {
  "station 1", 0, 97, {{19, -0.8, 96.9}, {0, 0, 0}, {0, 0, 0}, {14, -1.1, 94.5}},
My problem and how to make it better
As you can see I defined the analog pin (14,15,16,17,18,19) in struct ini_station and in t_bs18b20 and it's not a good idea.
How would you modify t_bs18b20 bs18b20 with two goal
  1. delete the analog pin indication const byte pin
  2. to make sure that bud1_actvate definition will macth the righ value.
Do you understand my goal?
The other idea, would be to not work with several struct, and to add bud1_setting in ```struct ini_station``
struct ini_station
  const byte bud1_setting;       // {0, 97,-0.8, 96.9} (refMin, refMax, min, max)
  const byte bud2_setting;       // {0, 97,-0.8, 96.9} (refMin, refMax, min, max)
  const byte bud3_setting;       // {0, 97,-0.8, 96.9} (refMin, refMax, min, max)
  const byte bud4_seting;       // {0, 97,-0.8, 96.9} (refMin, refMax, min, max)
   {0, 97,-0.8, 96.9}, //bud1_setting
  {0, 97,-0.8, 96.9}, // bud2_setting
  {0, 97,-0.8, 96.9},  //bud3_setting
{0, 97,-0.8, 96.9}, //bud4_setting
May be, it's look more simple.
Which best way you'd recommand me, with may exemples... :slight_smile:
Many thanks!!!
I finally did as the following.
Would you let me now if you would make it different and better?
struct t_ds18b20 { // for DS18B20 calibration
  float refMin; // Temperature of the ice
  float refMax; // Temprature of the boiled water
  float tMin;   // Measure in the ice
  float tMax;   // Measure in the boiled water
struct ini_station
  t_ds18b20 bud1_calibration;
  t_ds18b20 bud2_calibration;
  t_ds18b20 bud3_calibration;
  t_ds18b20 bud4_calibration ;
19,             // b1; p;     // 0=Unactive; *14=A0*; 15=A1; 16=A2; 17=A3; 18=A4; 19=A5
    {0,97,-0.8,96.9},      // ds18b20 calibration: refMin, refMax, min, max
    {0,97,0,0},      // ds18b20 calibration: refMin, refMax, min, max
    14,             // b4; s;     // 0=Unactive; 14=A0; 15=A1; 16=A2; *17=A3*; 18=A4; 19=A5
    {0,97,-1.1,94.5},      // ds18b20 calibration: refMin, refMax, min, max
May be I should add the pin here
  const byte pin; // Analog pin (14,15,16,...)
and remove bud_active
i think describing what your trying to do would be easier than trying to reversing engineer that understanding from the code you've posted
