Better way for programming with Arduino?
Hi there.
All this time I've been using Arduino IDE for programming, and I'm very happy with this environment.
But now, as programmer, I've reached a higher level. And I would like to use a better IDE.
My question is pretty simple: is there any IDE (mixed with the appropiated libraries) which could give me the next pros?:
  1. Dinamic programming: Autocomplete, easy navigation, ... You know, as Visual Studio does...
  2. Complete debug: Memory, variable values, breakpoints, ...
  3. Arduino libraries for compatibility with older codes made on Arduino IDE.
Does somebody knows an IDE which could give me all of them? I'm thinking about Visual Micro plugin (for Visual Studio). But I'm not sure if there is possible to debug at low level (memory navigation, for example).
Thank you in advance. And please, excuse my english.
My best regards,
Bivalvo.
  1. Complete debug: Memory, variable values, breakpoints, ...
How is a debugger running on the PC going to help debug a program running on the Arduino? When it is on batteries and not even connected to the computer?
Years ago (long before my first Arduino) I spent some time programming on my PC using NetBeans which is a similar concept to Eclipse.
In the end I gave it up in favour of the Geany editor which is what I now use for all my programming (including for my Arduinos). It just makes life much simpler.
And I have written a simple Python program to compile and upload Arduino code using the command-line IDE.
...R
PaulS:
For example using a debugger HW which is connected to USB port, as is done with other microcrontrollers. For example you can debug your program on TI using a MSP debugger and the IAR workbench.
Robin2:
...R
But on Geany you also have not access to the memory. I have to search more about this, but maybe ATMEL STUDIO would be the best option...
EDIT: Sorry, I mean AVR STUDIO
I use Sloeber. It integrates the Arduino core packages used by Arduino IDE into Eclipse. It has all your requirements and more. (I didn’t try debugging (JTAG)). One of the best features is instant opening of library source codes.
I use Eclipse for Java at work many years so I was happy I can use it for Arduino too.
bivalvo:
That's quite true. I have never felt the need for it.
And the Atmega 328 and 2560 MCUs don't have provision for accessing memory separately from the running program.
...R
Juraj:
I use Sloeber. It integrates the Arduino core packages used by Arduino IDE into Eclipse. It has all your requirements and more. (I didn't try debugging (JTAG)). One of the best features is instant opening of library source codes.
Also memory? :open_mouth: The possibility of debugging at low level is very useful
Robin2:
...R
Is very important when you're trying to find memory leaks, for example. If you're used to work at this level, it's a essential tool.
sorry, I never used mcu hardware supported debugging and I know nothing about it
Visual Micro has debugging functionality but some of it is just automatically added Serial.print() statements. It's also possible to do true on chip debugging with the right hardware. The Atmel ICE would be the current debugger of choice for the AVR (works for SAM also) MCUs. You can buy Xplained boards from Microchip that have an onboard debugger, though apparently it's not as good as the ICE. If you're into chips other than AVR that might change things.
I think it could be very useful to have the option of on chip debugging but I don't want to use Atmel Studio and haven't managed to get it working without Atmel Studio so I'm stuck with the Serial.print(). Well, that works OK for me so far.
bivalvo:
Why would you have those?
Don't you know what every byte is used for?
...R
Robin2:
...R
exactly. it is what I like on this small 8-bit chips (and don't like on esp8266)
pert:
Excuse me for the late response, but I had a few hard days...
Wow... Atmel ICE is SO expensive...
Maybe Visual Micro is the best solution... I've also worked with Serial.print() on my whole programmer's life, so I do not need much more... Only need to get used to it. Maybe Arduino IDE is not the best IDE, but its integration is (for example, adding plugins for different MCUs, etc.).
Eclipse IDE Arduno plugin uses the same board packages as the Arduino IDE uses
Juraj:
Hi, Juraj.
Is that option also included on Visual Micro? I’m more interested on this IDE
bivalvo:
Hi, Juraj.
Is that option also included on Visual Micro? I'm more interested on this IDE
I don't know
