Better way to arrange timed and continous events?
For now, I came to working code below.
Pros:
  • no delay()
  • all event frequencies are associated in relatively close places (crontab[] for frequencies and lastops[] to keep track of them)
    Cons:
  • handlers are scattered in timeHandler() and disconnected from events. Actually, there's no events, only side function to control different arrays
  • no built-in function to report actual array length
  • overall code is hard to understand and very hard to embed, because initiations and functions placed in different parts of document
  • biggest one: if a handler starts child process, it has to be embedded in same crontab[], linearizing tree, and this breaks my brain.
#define MIN 8
double crontab[] = {
  1000000/5, //playing note...
  1000000/1, //shifting frequency each 1 sec
double lastops[sizeof(crontab)/4];
  timer();
void timer(){
  for(int i=0 ; i < sizeof(crontab)/4; i++){
    if(micros() - lastops[i] > crontab[i]){
      lastops[i] = micros();
      timeHandler(i);
void timeHandler(int i){
  switch(i) {
    case 0:
      handler0();
    case 1:
      handler1();
void handler0(){
  Serial.println("flip...");
void handler1(){
 crontab[0] -= crontab[0]/20;
 if(crontab[0] < MIN){crontab[0] = MIN;}
 Serial.println("freq shifted");
And here is how I imagine it could be - simple and readable:
  crontab = { //multihash
	note {
		interval : 1000000 / 5
		handler : function (){
	shifter {
			MIN = 8;
  timer();
void timer(){
  for(i in crontab){ //or for(i = 0; i < crontab.LENGTH(); i++)
      if(micros() - crontab.i.last > crontab.i.interval){ //last is not defined, and it's OK!
      crontab.i.interval = micros();
      crontab.i.handler();
Will this help?
Likely, no. Your class adds very good replacement for delay representation, but events are still have to be handled inside sketch.
Well, luckily for you, the Arduino can only run one process, so this will never happen.
father_gorry:
[quote author=Nick Gammon link=topic=72690.msg545038#msg545038 date=1316341993]
Will this help?
Gammon Forum : Electronics : Microprocessors : Elapsed time class
[/quote]
I'm not sure I understand your response. Where else would the events be handled rather than inside the sketch?
You could make a table of the timer objects, test each one inside loop, and do one when its time is up. Isn't that the essence of timed events?
Sorry. I meant that this way and approach somehow results in one-level list of timer variables, and in order to make understandable clear multi-leveled code, I have to hide that list or table as far as possible.
In other words, one must program, thinking of "each-200us-timed events" instead of "that things happen again in 200us".
Anyway, both mine and yours ways failed to me, because I needed exact timing (to play tone with stepper motor). The real intervals were noised: 230, 250, 269, 203 us etc.
father_gorry:
if you need exact timing, you're going to have to use one of the hardware timers as opposed to a software implementation.
father_gorry:
... in order to make understandable clear multi-leveled code, I have to hide that list or table as far as possible.
... I needed exact timing (to play tone with stepper motor).
Understandable clear code, and exact timings may be mutually exclusive.
Small, fast, readable, you get to choose any two only. :wink:
