Nick,
Attached is code with digitalread as well as my output from the serial monitor.
I should be reading 0010-0111 but am instead reading 0001-0011.
Purpose: Read/Write to RI-R6C-001A Register
int SCLK = 7; // SCLOCK
int DIN = 4; //Data from main controller to transceiver ic
int DOUT = 3; //Data from transceiver ic to main controller
int val;
//Serial1.begin(9600);
Serial.println("Setting up Serial I/O");
pinMode(SCLK, OUTPUT); // sets SCLK digital pin as output
pinMode(DIN, OUTPUT); //sets DIN digital pin as output
pinMode(DOUT, INPUT); //sets the digital pin as input
Start Bit
Serial.println("Start Bit");
digitalWrite(SCLK, HIGH);
delayMicroseconds(1);
digitalWrite(DIN, HIGH);
digitalWrite(SCLK, LOW);
digitalWrite(DIN, LOW);
Write configuration register command 0x7D
Data - > MSB; Latched on Rising Clock Edge
Serial.println("Write 0x7D");
digitalWrite(SCLK, HIGH); //0
digitalWrite(SCLK, HIGH); //1
Write configuration register content 0x27
This is the value I am storing in the register
Serial.println("Write content 0x27");
Stop Bit
Serial.println("Stop bit");
Start Bit
Read configuration register command 0x71
Serial.println("Read Command 0x71");
Read back configuration register using controller clock = 0x27
Serial.println("Read Register");
delayMicroseconds(5);
Serial.println(digitalRead(DOUT)); //1
//var = digitalRead(DOUT); //read the pin and save it into var
//Serial.println(var);
Serial.println(digitalRead(DOUT)); //2
Serial.println(digitalRead(DOUT)); //3
Serial.println(digitalRead(DOUT)); //4
Serial.println(digitalRead(DOUT)); //5
Serial.println(digitalRead(DOUT)); //6
Serial.println(digitalRead(DOUT)); //7
Serial.println(digitalRead(DOUT)); //8
Stop Bit
